where is the vss located?
Old Aug 16, 2010 | 12:09 AM
949's Avatar
949
Default where is the vss located?
i recently got a cel for a bad vss signal. also at the same time my speedo gauge stoped working.
i am assuming that its just the vss. where is this item located?
what is the fix for this?
update:
as an update, with the help from these guys i found out very quickly that it was the speedo cable. it was broken in half.
Old Aug 16, 2010 | 12:38 AM
TeamRedline89Hatch's Avatar
Default Re: where is the vss located?
It's on the back of your transmission. Follow your speedo cable from the firewall and you'll find it
You can try to unplug it from the back of your cluster and clean the connection, reset your ecu and see if it fixed it.
Or have the car in neutral and push the cable down into your vss while rocking the car back and forth to make sure it's in all the way.
Old Aug 16, 2010 | 07:29 AM
949's Avatar
949
thank you.
on the tranny the line simply goes into the tube. i dont know if anything can actually be removed.
i will definitely try to push the line in while in neutral first.
so the vss is not in the cluster?
how do i test to see if the cable is broken?
its a 91 civic si.
Old Aug 16, 2010 | 07:46 AM
slywfbpsi's Avatar
thank you.
its a 91 civic si.
Yes the vss is in the cluster. If your speedometer has stopped working, more than likely your speedometer cable is broke. When you take out the cable from the tranny, you can pull of the cable and see if there is any play in it, i.e. able to pull and push it back in. That is your indication that it is broken. If you noticed that your speedometer would fluctuate at a given speed, say 30-40 mph, and then all of a sudden show the correct mph, that is an indication that your speedometer cable was going bad. You can get a replacement from the dealer for like $40.
Old Aug 16, 2010 | 07:52 AM
949's Avatar
949
wow, thanks guys!
you guys have been very helpful and professional with your answers.
+2
Old Aug 21, 2010 | 06:50 AM
949's Avatar
949
as an update, it was the speed cable. it was broken.
thanks again guys, exellent help.
Old Aug 21, 2010 | 03:11 PM
slywfbpsi's Avatar
np
Old Aug 21, 2010 | 05:15 PM
949's Avatar
949
now i found out the problem, a new one has arised. the dealership says the cable is no longer available for my car.
does anyone know if a 91 crx si cable will work on 91 civic wagon si cluster 4wd?
Old Aug 21, 2010 | 05:21 PM
B33BZ's Avatar
I ordered one from my dealership for an 88 sedan like a month ago. You may want to check out majestic though. This same dealership told me i couldn't order the ignition switch as one piece that i had to get a whole lock/key cylinder setup. Soooo dont always trust one honda dealership in your area. I'd call around or order one from majestic. Actually google was way faster and cheaper
http://www.google.com/products?q=199...ed=0CDcQrQQwAg
Old Aug 21, 2010 | 05:29 PM
949's Avatar
949
actually majestic also says its discountinued. i looked for a crx si and the number is different. it has the same picture but its a generic picture.
i dont know what the difference is.
here is the link to majestic for the crx and the wagon civic
91 civic crx si
http://www.hondaautomotiveparts.com/...BINATION+METER
91 civic wagon
if you look for #4 on both, one will be available and the other isnt.
also i noticed that #1 which is the inner replacement part for the cable, have different part numbers. suggesting they are different, but i dont know what is the difference.
Old Aug 22, 2010 | 12:49 PM
kylelee08's Avatar
similar issue, my 95 accord ex, the odometer, then the speedometer stopped working. They both will kick back in and work perfect every now and then, but not often. Now, just last week, i uninstalled my amp(baby on the way) and they seem to work more often...buut, they kick out when i turn on the lights? wierd?...could it just be a bad ground?
Old Aug 22, 2010 | 02:23 PM
hoga113's Avatar
The #1 & #4 come together, I'm looking up on http://estore.honda.com as now, they still have the cable available for 91 civic si part #78410-SH3-A02 $27.56, the same with the 91 CRX si. I just replaced mine while ago.
Old Aug 22, 2010 | 02:25 PM
hatchet_honda's Avatar
update:
how would you get a cel for a cable driven speedo? i assume its not the d16a6 motor??
Old Aug 22, 2010 | 04:36 PM
Unplug yours and find out
I forgot to hook mine up when I did my swap last night lol, stupid me.
Old Aug 23, 2010 | 10:43 PM
949's Avatar
949
im mostly concerned if the length is the same. my 91 civic 4wd wagon has a different part number as to any other civic that year. the hatch, crx, si versions have all the same part number.
you can get a cel from not having vss. also i did an obd1 conversion so that will definitley not work right cause i have vtec now too. the ecu uses that signal to determine a few things.
GPC91
Sep 17, 2012 01:11 PM
KhmerdudeSiR
13
Nov 12, 2008 01:52 PM
shai x boi racer
Jul 14, 2005 04:52 PM
PimpTightSi
Sep 18, 2002 06:52 PM
Brian_92GSR
Jun 24, 2002 08:14 PM
