How big can you go without sacrificing A/C(pics welcome)
Old Aug 15, 2010 | 08:33 PM
StreetRacinThug's Avatar
Default How big can you go without sacrificing A/C(pics welcome)
I have put together a few cars in my time that made great power. I am finally keeping a car for once after my stuff got stolen long ago.
Current set up.
96 Civic HX
B16A
ITR Mani
DC Header
Stock Cat and Stock Intake
Plans:
B18C5 Block,
Block guard
10:3.1 Pistons
Eagle Rods
Stock Crank
ACL Bearings
ARP Mains
B16A Head: ITR Cams/Pro 1s with Springs and Retainers
1000cc Injector Dynamis
E85 NUFF SAID
Now Derek Robinson will be tuning the car for me as he has before.
He tuned a pistons and rods LS/VTEC for me on and made 420WHP on T04E 3" Hot side on 20lbs.
Also tuned my last put together car GSR with ITR Cams, BLOX ITR Mani with Headstuds on a SC61 at 12lbs made 410WHP.(Amazing)
Now my question for you gentlemen is how big can I go without messing with the A/C lines and stock condensor. I think the best I can do is put a slim fan on the other side and tuck the consenser under the radiator support to add room for a Downpipe or charge pipe. I would also heat wrap my lines and down pipe. A turbo blanket might be used.
My biggest thing in this factor is I dont like sweating anymore than I have to. I love power steering and A/C. I know much of you guys think oh this guy is a ***** bla bla bla Power steering and A/C is for wussies. Well I think I have owned anything from 92-00 and any B swap, H swap, and K swap.
I have had my good 8 years of Hondas with no PS or AC. My final car isnt going to be the fastest or the freshest but can be a practical car that offers the UMPH that I desire without losing driveability.
E85 is going to be used for great mileage, availibity, cost effective, also high octane
1000cc Injector Dynamics for driveability, and no wiring mess....plug and play
A/C I LOVE IT
My goal is simple. 400-500whp on HiBoost. Boost by gear. Neptunes. E85. Built Block. AC. Daily Driver.
I think its feasible. Call me crazy but its been done before without AC and I think I can do with it. Again my compression levels are higher than average for more power on less boost. Yet safe.
All opinions please chime in. Any good flowing AC compatible manifolds and downpipes or kits? Post pics of your A/C Turbocharged B Series.
Oh for the pics here are some of the whip. I know the pics it shows that it doesnt have A/C but it does.
Old Aug 15, 2010 | 11:55 PM
joe111599's Avatar
Default Re: How big can you go without sacrificing A/C(pics welcome)
www.speedfactoryracing.net/store
They have kits that will fit your car and still retain ac and ps. They do GREAT work man! Hit them up.
Old Aug 16, 2010 | 12:05 AM
SDHonda153's Avatar
This is in an EJ1 with PS, A/C, Cruise, ABS, everything it came with from the factory. It's the Full Race A/C compatible manifold with a GT3076R. Make's 400hp and still blows cold A/C. Granted I wrapped the manifold, dump tube, down pipe, A/C lines and put a blanket on the turbo.
Old Aug 16, 2010 | 01:21 PM
E85B18's Avatar
For sure it's doable. As seen above the full race manifold is awesome. Only thing is you have to run a 1/2 radiator.
Old Aug 16, 2010 | 03:54 PM
EsotericImage's Avatar
Retired Moderator
+1
Old Aug 16, 2010 | 04:30 PM
AlexDphoto's Avatar
clean bay, i like
Old Aug 16, 2010 | 05:22 PM
ZenkaiRacer's Avatar
Everyone keeps mentioning the a/c compatible manifolds from speedfactory. I can't find the manifold on that site. I'm looking for one for a d series.
Old Aug 17, 2010 | 02:04 AM
Zer0_SpeedWorks's Avatar
fitted a t67 on my bseries eg hatch...relocated the ac line though...
Old Aug 17, 2010 | 08:33 AM
powerneedy's Avatar
http://www.lhtperformance.net/turbo_...ht_type_r.html
Old Aug 18, 2010 | 12:45 PM
SAXON's Avatar
full-race... do it right and do it once, im sure derek will agree with me on this
Old Aug 18, 2010 | 01:07 PM
BoostR41's Avatar
I had a T3/60-1 with S compressor cover on a RLD-Fab AC mani on my integra for 3 years. Ac worked ok but if I had wrapped the mani, etc it would have worked better. I made 550whp on race gas and 400whp on pump gas at the time
Old Aug 18, 2010 | 04:40 PM
lunareg's Avatar
im stuck in the sweat your ***** off camp.. wish i had ac . . I end up driving my DD if its to hot out.
Old Aug 19, 2010 | 01:59 PM
Thanks for all the replies i guess ill just buy the full race manifold and piece a kit together
Old Aug 19, 2010 | 06:25 PM
jetspeedz's Avatar
My suggestion to you is to spend the money up front and do it right. Also AC lines are a bitch and most of the time will be an issue with fit. I had to make custom AC lines. The design of the manifold and where the downpipe connects to the turbo can be an issue with the compressor being real close to each other. Good luck
Old Aug 19, 2010 | 07:03 PM
slywfbpsi's Avatar
they don't make an ac compatible one for the d series.
Old Aug 19, 2010 | 07:41 PM
By half you mean in thickness? That sucks...I have a Koyo currently installed so I will have to either tuck it or switch it.....Ehhh I definately dont want to give up my expensive Koyo. Im pretty sure its dual core.
Old Aug 19, 2010 | 07:47 PM
1158's Avatar
Your rad will be fine. The full core rad in the Integra is what I believe they were talking about. I had to swap out my full core stock Integra rad for a half core Koyo.
Old Aug 19, 2010 | 08:57 PM
jetspeedz's Avatar
I think you guys got size and core mixed up. Full size single core is what comes standard in the integra. You will need to run a half size Dual core radiator if you want to keep your AC.
Old Aug 19, 2010 | 09:09 PM
1158's Avatar
That's what I was telling him. He has a civic, so he doesn't have a full core rad. He has the half core rad. He was thinking half core meant he had to use a single core civic rad. A dual core civic rad will fit fine.
Hope that makes sense...
Old Aug 19, 2010 | 09:15 PM
jetspeedz's Avatar
lol, your making the same mistake bud. Your statement above "full core" & "half core" does not make sense, its full Size or half size. The core is the thickness so "full thickness" does not make sense, hope that clears things up for you. cheers
Old Aug 19, 2010 | 09:26 PM
1158's Avatar
Yeah, I see what you mean. Terminology getting swapped around. Like using all motor when technically the term should be all engine or NA.
Anyway, the Koyo civic rad will work. That should hopefully clear up any confusion that was created.
Old Aug 20, 2010 | 12:35 AM
slowtegkauai's Avatar
I went to the web site you posted speedfactory.... I found a mini ramhorn manifold for $450 which i think is AC compatible.. take a look when you got the chance
Old Aug 20, 2010 | 01:09 AM
joe111599's Avatar
YES they do!!!! You have to call them. Speak with Matt or Ricky. I was going to be their first a/c compatible customer but backed out at the last minute because I couldnt wait the extra time to fabricate. But Ricky was ready to weld it up for me. All you gotta do is call. THEY WILL MAKE ONE I PROMISE!!!
Old Aug 22, 2010 | 04:43 PM
Ill give them a call and see whats up. Thanks guys I am happy to hear that I can keep my Koyo.
Old Aug 22, 2010 | 05:11 PM
slywfbpsi's Avatar
LOL, saying that they do, but then that they will have to fabricate one first, does not mean they have molds steadying available. All right here https://honda-tech.com/forums/showth...6#post43362836
