question on wheel offset and size
i got a 96 accord and im looking at a set of rota d2's online and they say there for a 200 sx or 240 sx but have my lug pattern with a 20mm offset 7.5'' front and 8.5'' rears i had a set before just dont remeber the offset questions is they should fit any info thanks....
Offset plays a huge factor, what size of the wheel is it?
16" or 17" with a +20 offset (very low) with 7.5" and 8.5" width I'm going to wager you'll rub.
I'm going to say you will rub if you're lowered at all.
I run 17x8 +35 17x9 +38 with my S2000 only lowered 1".......... I can only imagine what an extra 15mm would do
I'm running RSX 5-lug 17x7's with 45mm offset and don't rub at all, even lowered ~1.2". I couldn't go any higher on the offset or the rim would rub the rear lower arm and maybe something in the front also.
I think it will rub with 17's if lowered. Assuming u will b lowering it. I am running 16x7 and 16x8 with 24 offset and tire spec is 195/50r16. I had to cut the rear inner part of the inner lip so the tires won't rub. And it doesnt rub at all even if slammed.
why are you going to put staggered wheels on a FWD car that came with non-stagered fitment from the factory?
anyways, a 8.5" wide +20 offset wheel isnt going to fit regardless. i would look into a more standard fitment
cause i want to and it will fit so your wrong but anyways can close thread or w/e got the info i needed.................
8.5's with 20 offset all around so they will fit thanks
just because they are on the car doesnt mean they "fit"
those tires are obviously stretched, which is unsafe and the wheels still stick way out. they are not the proper wheel size for the car but in the end its up to you. GL
mrlegoman
Jul 6, 2006 01:29 PM
