Out the top or threw the bottom?
Old Aug 15, 2010 | 03:03 PM
Tims Toy 500's Avatar
Default Out the top or threw the bottom?
ON a D15 - with the intake manifold still on will the engine. Should it come out threw the bottom or does It need to come out the top?
Any thoughts?
Old Aug 15, 2010 | 03:07 PM
mayfly's Avatar
Default Re: Out the top or threw the bottom?
either. are you swapping the engine? you can do either.
Old Aug 15, 2010 | 03:15 PM
It’s time for me to do a clutch job. I figure just a few more bolts and the engine will come out. Right? Then I can easily do that wire tuck job I’ve been dreaming of.
Old Aug 15, 2010 | 03:19 PM
So, with the intake mani - it will fit threw the bottom??? Any tricks I should know of?
Old Aug 15, 2010 | 03:22 PM
1991civicsi's Avatar
I pull the head then take the trans/block out of the bottom.
Old Aug 15, 2010 | 03:26 PM
DVS_SI's Avatar
You dont need to pull the head. The whole thing will come out of the bottom. Is the car going to be on a lift?
Old Aug 15, 2010 | 03:30 PM
Jack stands. But I have access to a lift if absolutely needed.
Old Aug 15, 2010 | 06:15 PM
DVS_SI's Avatar
It is easier on a lift but jack stands will work but you have to get the front really high to get it out of the bottom.
Old Aug 15, 2010 | 09:03 PM
uberEFtuner's Avatar
Use chains to connect to the front tow hooks from in the engine bay. Lift the car with an engine lift. Slide the engine out. Its really that easy. Be safe and don't get under the car while its in the air. Use rope or chain to slide the engine out.
Old Aug 15, 2010 | 10:23 PM
Zaakro's Avatar
If you have an engine hoist just use it to pull the motor out from the top. Why do the extra work to get it from the bottom.
Old Aug 16, 2010 | 12:40 AM
DCRB's Avatar
i've done both. i find through the top is easier for me, if the trans is still attached to the motor. if not through the bottom is definitely the easier way to drop it. i don't like fighting with radius rods and all that junk
Old Aug 16, 2010 | 01:50 AM
Heeyy... I like that idea!
Another question to add to the mix, do I need to remove the radiator and fans?
Old Aug 16, 2010 | 01:55 AM
The tranny will be separated at this point. As mentioned above this crazy idea started its life as a clutch job turn to wire tuck.
Old Aug 16, 2010 | 06:30 AM
Jockone's Avatar
If you have the engine hoist why not just pull engine and trans together out the top and split them on the floor to do the clutch?
Bright13
May 27, 2016 01:36 AM
Xextr3meX
Nov 16, 2015 07:17 PM
Yuta
Nov 1, 2015 08:20 PM
tronic
Feb 20, 2011 11:57 AM
