95 Odyssey Pwr Window issues
will try to be brief and detailed: right front and right rear windows work normally from their own switch, but will only do down from master switch. I checked voltage at the motor swith on each right door:
(2-wire connector at motor - disconnected)
B+ voltage on "up" wire when controlled from master switch
B+ voltage on "Down" wire whe controlled from master switch
*B+ voltage both directions controlled from right door switch
(2-wire connector at motor - connected)
3-4 volts on "up" wire when controlled from master switch
At first I suspected the motor, as it gets the proper voltage from the master switch when the motor is disconnected (possible short); but that wouldn't explain why it works from right door switch, right?
PLEASE HELP!!
Also, anyone know of a good new/used parts dealer near greenville/spartanburg, SC?
THANKS!
PLEASE HELP!!
THANKS!
H.N.F
May 18, 2016 07:42 AM
cksnah252
May 23, 2015 09:10 PM
BlueIntegraBoy
Apr 14, 2008 10:23 PM
