Honda CR-V & Element 2WD & 4WD Element & CR-V
Replacing exspanion valve in my 2005 Honda CR-V
Old Aug 13, 2010 | 09:08 PM
My96hondadriver's Avatar
Default Replacing exspanion valve in my 2005 Honda CR-V
I am trying to replace my ac exspanion valve in my 2005 Honda CR-V.
I can't find it and I was wondering if someone on here had a procedure and diagram on replacing it?
Can one of you all help me please?????
Really would make my wife happy....
Thank's my96Hondadriver........
Old Sep 8, 2010 | 07:07 PM
SpringerPop's Avatar
Default Re: Replacing exspanion valve in my 2005 Honda CR-V
It's bolted to the evaporator core, and you've gotta' pull the core to do the job.
Pop
Old Sep 9, 2010 | 05:52 PM
99blackcivicSi's Avatar
remove glove box
cut the plastic piece where the marks are
remove pcm and bracket
remove all harness connectors and clips
remove 5 or 6 bolts holding the blower box in
remove blower box
remove 8 or 9 screws holding evap cover in place
remove the 10mm bolt holding the lines to the expansion valve under the hood
pull lines off
remove evaporator and unbolt the 2 allen head bolts to remove the expansion valve
reassemble
i have done a ton of these any questions feel free to ask
Old Sep 14, 2010 | 07:41 AM
Duane_in_Japan's Avatar
You first need to know how you are going to re-service the AC system, I assume that you want to do this part of the job yourself but you will have it professionally recycled. You can have a shop remove what freon is in the system and that freon will remain yours if its not contaminated. YOu should get a credit for that amount on the recharge when you are done with the TXV replacement. You need new Orings and put a touch of AC oil on them, do not overtorque any fittings you put back together, the Orings do most of the work.
You would be best served to have the system made operable, unless the TXV is completely blocked, put some dye in and let it run for some time and sit for some time to try to find out if the evaporator is leaking when you remove it, the shop can take a quick look at it once you pull it out, then they can survey the rest of the system to see if you need any further work done also.
Old Sep 15, 2010 | 11:06 AM
mconkel's Avatar
Originally Posted by 99blackcivicSi
remove glove box
remove blower box
pull lines off
reassemble
Old Sep 15, 2010 | 05:11 PM
honda fossil's Avatar
are you sure it needs replaced what were you high and low side pressure cuz the tend to make a hooting type noise when low on refridgerant .
Old Sep 16, 2010 | 12:48 AM
sam.mark's Avatar
Excellent blog post, I look forward to reading more.
Thank you for bringing more information to this topic for me.
Old Sep 16, 2010 | 05:06 PM
probably because it did the typical crv thing where the compressor explodes and shoots shrapnel everywhere and kills the entire system the technical term is black death
Old Sep 16, 2010 | 05:22 PM
o yeh those thing look like a granade went off in side the compressor we get 7.5 hour for compressor clutch coil both hoses (high and low) and reciver dryer and a sys flushand recharge
93civicsedan
13
May 21, 2012 12:18 PM
Liquidgsr
Apr 26, 2006 10:20 PM
giff74
Mar 19, 2005 02:09 AM
