stock oil cooilng d16 block
Old Aug 13, 2010 | 07:52 PM
2kdrift's Avatar
Default stock oil cooilng d16 block
im trying to switch my stock oil cooler from my d15z1 to my d16z6. i have the cooler removed i need to now remove the threaded tube on the z6 where the oil filter goes. has anyone done this before? its hard to grip so my only idea is to dirll a hole straight through it, and use the bit to turn the threaded tube and loosen from engine.
chek picture
Old Aug 14, 2010 | 02:20 AM
2kdrift's Avatar
Default Re: stock oil cooilng d16 block
got it drilled it out like i said.
if you plan to do this make sure you cover teh block carefully as you dotn want any oil shavings inside. once you have taht removed
heres what parts you will need to install the oil cooler.
cooler, bolt and a nipple that screws into your block (water port), also you may need to change your water pipe if you dont have a extra port for the cooler on your current one.
and here it is on my b7 block, had to ditch the z6 it was no good
booboo782
Sep 23, 2010 06:30 AM
2kdrift
Aug 15, 2010 07:17 PM
brokeHonda
Jan 9, 2006 07:23 PM
riceball777
Jan 23, 2004 11:18 AM
HybriDNA
Dec 27, 2002 07:12 PM
