Toda cam spec a my car got slower after install tada cam
Please all the pro out there if u know anything thaat can help me out right now I will be very appreciated.
My situation now is.
I am currently running b16a2 engine in my EK.
and my question is ....I just reasonly bought a set of toda spec a cam shaft.
and installed. and the result is........my car got slower?
very slow actually.....I lost lot of low end power? ....is that normal?
need dyno tunning?
need dyno tunning?
how confident are you that you got the engine timing correct ? this is not ign timing, this is with lingin up TDC on crank with TDC on cams. Then you also needed to readjust valvelash. Ideally you should have also degreed the cams with adjustabl ecam gears until you hit the dyno, if not jsut hit the dyno and tune them.
Greg
Greg
I don't know a lot about cams but I belive they are designed that way. If you have a lot of high end power than you wont have a lot of low end power. That may just be the way the cam was designed. if your not supposed to have power like that in that range of RPMS, they may have given you the wrong cam. You might want to check on that or call there tech. support.
The guy needs to get it tuned. VTEC Xover, fuel, timing.
Si Jeff
Southwest (Sales)
Sep 19, 2012 11:04 PM
B18 CYA
60
May 22, 2006 01:22 PM
BlackGSR
Nov 16, 2001 09:17 AM
