Need Bungs Welded to Valve Cover...
Old Aug 12, 2010 | 05:25 PM
Brooklyn101's Avatar
Default Need Bungs Welded to Valve Cover...
Anyone know a reputable shop that could weld 4 bungs to a minty moon cut valve cover?
My JDM ITR Red Valve Cover is clean with a nicely done moon cut so i want to locate a good welder who can do a good job welding the bungs on the valve cover.
Located in Houston, TX. Thanks!
Old Aug 12, 2010 | 05:32 PM
93ls10.0's Avatar
Default Re: Need Bungs Welded to Valve Cover...
just drill and tap the cover no welding required worked great on my ls
Old Aug 12, 2010 | 06:01 PM
heard some pros & cons about that....imma be pushing about 600whp, think it'll be safe with that much crack pressure with no leakage....
thanks!
Old Aug 12, 2010 | 07:20 PM
93ls10.0's Avatar
I run 450+hp on mine and have only had one leak some pipe dope and it has never leaked since. If its that big os a concern you can get a nut for the back side for insurance.
Old Aug 12, 2010 | 11:47 PM
AFFIRace's Avatar
I would hit up locash for fittings. They work great for welding on the inside of your valve cover for a clean look on the outside. Just like threaded ones but with that peace of mind knowing its solid and won't ever leak. As for a welder.?
Old Aug 13, 2010 | 01:48 AM
SD_Lurker's Avatar
HT White Ops
What about the internal baffle? You don't wanna do without that badboy..
Old Aug 13, 2010 | 06:43 AM
mikesrex's Avatar
hit up BMCRace, he is actually a sponsor here and has a dynasty 600 welder at his shop. he will be able to make some fine looking welds for you.
Old Aug 14, 2010 | 08:55 AM
swappedcx's Avatar
Uhhh...yellow pages? My last one I took to my college and had the welding teacher tig it for free. It's just a valve cover. Drill the holes yourself and just look online for a local place.
Old Aug 14, 2010 | 12:58 PM
SD_Lurker's Avatar
HT White Ops
dynasty 600? WHere did he get that? I want one..
Old Aug 14, 2010 | 02:29 PM
ej8_99's Avatar
t1 race development does a great job. theyll run the lines to a custom catch can. theyre in dfw area
Old Aug 14, 2010 | 07:39 PM
mikesrex's Avatar
i believe that's what he has, you can PM him to find out more. I bought his old syncrowave 180SD when he got the new rig.
Old Aug 14, 2010 | 08:18 PM
BMCRace's Avatar
I can do it for you
give us a call at 281 398 6666, bring it by tomorrow sometime if you choose, we are pretty much open 7 days a week.
Also what size fittings do you need?
If its -10 we have plenty in stock as that is what we use on the fuel rails.
its the Dynasty 700 Complete Package actually
http://www.millerwelds.com/products/tig/dynasty_700/
b20beast83
Feb 5, 2009 06:33 PM
b20beast83
Feb 4, 2009 01:23 PM
allmotorhatch
Mar 8, 2005 09:46 AM
FLCivic
Jul 30, 2002 10:46 AM
