98 VSM complete shell complete b18b, coilovers, sway bar, turbo parts, seats, etc
Located in San Diego CA. Local pick up prefered but shipping can be arranged.
SHELL ENGINE SEATS X BAR SWAY BAR ALL SOLD!!!!
Turbo parts fs
Exedy stage 2 clutch ...STOLEN by kevs-ej1
ACT 10lb flywheel with ARP flywheel bolts...STOLEN by kevs-ej1
I didnt have tools at the moment to take my clutch out when I sold him my b18b so I gave him the benefit of the doubt when he told me he would return it to me. All I can say is im glad I dont have to deal with this scene anymore and karma is a bitch.
Jet coated Drag log manifold + wastegate elbow...160obo
straight pipe + wastegate dumptube + wastegate elbow...SOLD to SD-EK
(NEW) obd2a > obd1 ECU conversion harness from phearable...SOLD to SD-EK
obd1 b18b1 ECU with Basemap from phearable.net chipped and socketed for tuning. I set the launch control at 5500 I believe and has a CEL shift light. $150obo
air research T3 60/48 off a ford thunderbird. hit full boost at 3.5ish on my LS...minimal shaft play...sold
Tial 38mm wastegate with 5psi spring and 12 psi spring I believe....160obo
aluminum charge piping with couplers and clamps with intercooler ...includes injen short ram intake pipe with HKS bov flange for steatlh piping.(intercooler used for 5 miles)...160obo
550cc RC injectors with jumper harnesses so no need to cut and run resistor box/injector plugs...250obo
fast turbo vacuum manifold SOLD!!!!
HKS SSQV blow off valve...SOLD!
moroso oil pan (5 quart) includes magnetic drain plug...200obo
autometer boost gauge (NEW without box)...obo
civic half core radiator to fit turbo manifold. Used for 5 miles driving up and down my block.... 80obo
Turbo parts fs
Salvage due to theft : (
I guess ill start it off at 1500obo for the shell with the coilovers and no wheels. It can be cheaper if you want to bring your own suspension or have me remove some things. Im gonna try to find some stock shocks to replace the coilovers. The shell is very nice in terms of interior and paint. Garage kept and its been clay barred many times in its life.
Id consider 1600 for everything below. Certain things can be removed to make it cheaper. The whole kit is bolt on.
Jet coated Drag log manifold with 3 inch downpipe to straight pipe + wastegate dumptube + wastegate elbow...350obo
(NEW) obd2a > obd1 ECU conversion harness from phearable...75obo
air research T3 60/48 off a ford thunderbird. quick spool.....200obo
Tial 38mm wastegate with 5psi spring....160obo
aluminum charge piping with couplers and clamps with intercooler (new)...200obo
255 lph fuel pump obo
fast turbo vacuum manifold obo
HKS SSQV blow off valve with injen intake pipe with HKS flange...200obo
motorolla 2.5bar map sensor obo
moroso oil pan (5 quart)...200obo
Stainless steel oil feed and return...obo
You have 6 things I need to buy and I have cash so...Give me a call @ 619-550-8707.
