Turbo
Hey guys i have a h22a engine in my prelude and i was really wanting to turbo it? ive heard i can turbo the stock engine just dont go above 8 psi. what do yal think, i really need some help here.
and is this a good start?
http://www.cxracing.com/mm5/merchant...-H22-T04E-5BFG
And that link is garbage, parts are not reliable. Research, you're a long way from building this thing.
would i need to modify any of the engine parts for this turbonetics kit? is this a good kit?
or should i try to piece together a turbo setup?
http://www.andysautosport.com/honda/...b00091770.html
or the maxrev turbo kit which has
• Max Rev TIG Welded T304 Stainless Steel Turbo Manifold
• Garrett T3-T04E - .63 A/R Turbocharger
• Tial 38mm Wastegate .4 Bar Spring
• Max Rev 2.50 or 3.00 Inch T304 Stainless Steel Downpipe
• Max Rev Mandrel Bent 2.25 Inch Charge Air Tubing
• Max Rev Large Aluminum Front Mount Intercooler
• Max Rev T-6061 Billet Aluminum Blow Off Valve
• Max Rev Stainless Steel Oil Line Kit and Fittings
• Max Rev Quality Turbo Installation Kit
Part Number: H22: 1300.0103.9201 – H23:
No, you can turbo an h22 without taking apart the motor, but there are limitations in place that if not kept within that range you will end up blowing up your motor, but you should definitely have it professionally installed and tuned. Take it to a reputable shop. Also keep in mind that any turboed car has a "timer"... eventually your going to need a new motor or a rebuild with a turbo application, and much of the longevity of your stock motor relys on its tune.. crappy tune means your motor will not last as long. The tune could make it last from 2 months to 2 years.. Also depends how you drive and boost pulls.
To answer your question above, generally speaking, ive seen that a general turbo setup for an h22 is no more than 8 pounds on a t3/t4 setup.. Turbos are not all about the psi output.. you have to take in consideration the size and volume of air the turbo will push. There are endless combinations and setups.
What exactly is done to your car, please share. There is a ton of things you need to do to prep before installing a turbo.
if your going to go the turbo route...or really do anything performance wise for that matter... it is definitely recommended that you learn and do some research on turbo setups and applications, and how everything works in general so that you are self aware. The more you know, the better. Also... so you don't get screwed over.
also.. imo it's a waist of money to buy an already put together kit.
i havent done that much to my engine, i bought the car and it already had the h22a engine swap, a k&n cold air intake and aftermarket radiator
so your saying just to research and put together my own turbo setup?
what he means is ur gonna need to re-sleeve ur motor to beef up ur cyl walls and low compression forged pistons cuz stock cant handle too much up grade this and that,port n polish, tuning and etc!!!!!!!!!!endlless possibilities
dornon13
Feb 8, 2009 04:44 PM
Dorikamu
Nov 4, 2002 12:21 AM
