Anyone here with Toda A's in their 00 ITR?
Old Sep 16, 2002 | 10:32 PM
Hard2Find's Avatar
Default Anyone here with Toda A's in their 00 ITR?
anybody here running Toda A's with I/H/E?
how's the power compared to stock cams? whats the PLUS/MINUS of this cams?
Old Sep 17, 2002 | 02:26 AM
kenji's Avatar
25 Year Member
Default Re: Anyone here with Toda A's in their 00 ITR? (Hard2Find)
You will gain about 3-7 Hp throughout the powerband over stock ITR cams after tuning.
There are no downsides to these cams. You can run stock valvetrain if you want and they idle like stock.
Good cams.
-kenji
Old Sep 17, 2002 | 04:18 AM
Hooch'n's Avatar
Default Re: Anyone here with Toda A's in their 00 ITR? (kenji)
down side...........$
Old Sep 17, 2002 | 04:44 AM
Down_Und_R's Avatar
Default Re: Anyone here with Toda A's in their 00 ITR? (Hooch at 8400-RPM)
3-7hp does not seem like a huge gain for the $$ mind you I guess you can run pretty much everything else stock with these cams..........hmmmmm A's or B's
Old Sep 17, 2002 | 08:03 AM
sgT's Avatar
sgT
Default Re: Anyone here with Toda A's in their 00 ITR? (Down_Und_R)
With headwork, that gain will increase
Old Sep 17, 2002 | 08:53 AM
type r 01-1063's Avatar
Default Re: Anyone here with Toda A's in their 00 ITR? (sgT)
with port and polish there will be an increase.
how about increasing rpm to 9 or 9.5 K? (or upgrading valvetrain along with it)
Old Sep 17, 2002 | 09:14 AM
DaRKniGhT ITR's Avatar
Default Re: Anyone here with Toda A's in their 00 ITR? (type r 01-1063)
If your gonan upgrade valvetrain and port and polish..dont go with the A's...supermild cams...youll see much bigger gains with the B's...for a nice lil bump on stock without changing the valvetrain A's are good...with some tuning...
Old Sep 17, 2002 | 09:32 AM
Todd00's Avatar
I said I don't want a title!
I miss my A's...
Anyways, if you go all out on valvetrain, go with B's. A's are a great plug and play cam with only a vafc and camgears needed to run correctly.
Money saved with A's = more money to put toward a good suspension.
Old Sep 17, 2002 | 09:46 AM
Default Re: Anyone here with Toda A's in their 00 ITR? (Todd00)
good call...how much is a set of A's anyway?
Old Sep 17, 2002 | 11:06 AM
uNF$@#!'s Avatar
the increase in rpm wont help A's.
the power band quickly drops after 8600.
go spec B's or C's if you want to rev to 9500 +
Old Sep 17, 2002 | 11:09 AM
Hooch'n's Avatar
Default Re: Anyone here with Toda A's in their 00 ITR? (Soup ****)
Suspenison=Good idea!
Old Sep 17, 2002 | 02:15 PM
How much is a set of A's?
Old Sep 22, 2002 | 09:49 AM
Rob :190:'s Avatar
Default Re: Anyone here with Toda A's in their 00 ITR? (2000integragsr)
I saw a dyno and the Toda spec A's are not worth the upgrade in a type R. The Spec B made 190hp at the wheels on the Type R I saw.
thats purely opinion. SgT has dynos of A's making 200whp i think, so it all depends on the tuning.
Old Sep 22, 2002 | 09:52 AM
B2FiNiTY's Avatar
Default Re: Anyone here with Toda A's in their 00 ITR? ( Rob)
It really is how you tune it and what other kind of work you have done to the motor. There are guys here making 200whp with stock cams...anything is possible really as long as you do the right things.
Old Sep 22, 2002 | 10:04 AM
Rob :190:'s Avatar
Can you run Toda spec B's and have a reliable everyday car?
yes, definately. there are plenty of people on this board who daily drive B's and even C's. as long as its tuned correctly, you will be fine
Old Sep 22, 2002 | 11:05 AM
Shark Tank's Avatar
Tuning and regular maintenance are the keys when running bigger cams and aftermarket parts in general
Old Sep 22, 2002 | 01:03 PM
2001TypeR's Avatar
I think it also matter what parts you already have in like i/h/e....
Old Sep 22, 2002 | 01:47 PM
BlackGSR's Avatar
Default Re: Anyone here with Toda A's in their 00 ITR? (2001TypeR)
Toda A's are great camshafts that provide a nice increase in horsepower without upgrading the ITR valvetrain (a nice plus). However, I don't feel they are worth the price knowing B's are *ONLY a couple of dollars more.
I'm starting to like the Skunk2 stg 1 camshaft. I feel these will produce more horsepower than the Toda As and cost a lot less.
Old Sep 22, 2002 | 02:15 PM
Zeus's Avatar
From your comments, I'd suggest you do a search on Skunk2 stage 1 cams... sounds like they might be exactly what you are looking for...
Old Sep 22, 2002 | 05:04 PM
Default Re: Anyone here with Toda A's in their 00 ITR? (Zeus)
How much are skunk 2 stage 1 cams? cause im looking for a nice plug and play set of cams too...i was actually recommended to buy the jun's...
Old Sep 22, 2002 | 05:18 PM
Zeus's Avatar
Default Re: Anyone here with Toda A's in their 00 ITR? (DaRKniGhT ITR)
I don't have Shunk2's at this point, but from the research I've done, they'd be the first pick for what was asked. I'd say there is no such thing as "plug and play" cams... but if your refering to not having to use an upgraded valve train, it can be done with the stage 1s... you will have to do your own homework on where you want to buy...
Old Sep 22, 2002 | 05:27 PM
Which is were you guys come in....ive been asking and looking for a couple months now...just gettin all the feedback i can..
Old Sep 22, 2002 | 07:09 PM
Rob :190:'s Avatar
from what i've seen, the skunk stage 1s mimic the stock ITR power band, with 5-10 more hp, which i think is a good thing. the stage 2s are like B's and would need valvetrain upgrades. Like someone said, there is no such things as 'plug and play' cams, any cams will need to be tuned with a * minimum * of cam gears and VAFC, at least if you want to get your money's worth.
Old Sep 22, 2002 | 07:14 PM
CStyles45's Avatar
I daily drive my R w/ my Spec B's. Nothing but with my whole setup. My dyno numbers are in my sig.
Old Sep 22, 2002 | 10:07 PM
Default Re: Anyone here with Toda A's in their 00 ITR? (CStyles45)
What other mods do you have to help achieve those numbers?
