To those with JDM 4-1 headers...Hell to those with JDM headers
Old Sep 16, 2002 | 10:05 PM
ITR#132's Avatar
Default To those with JDM 4-1 headers...Hell to those with JDM headers
Noticed it was tearing for a while, and the last time I was under the car, it tore all the way through.
Old Sep 16, 2002 | 10:06 PM
Reid's Avatar
Global Moderator
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (ITR#132)
Is that the JDM header support?
The USDM support cannot be used with a JDM header.
Old Sep 16, 2002 | 10:09 PM
ITR#132's Avatar
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (Reid)
No, its a JDM support...Hence the title of the post
Old Sep 16, 2002 | 10:12 PM
Reid's Avatar
Global Moderator
Don't worry about it, that bracket is unnecessary anyway.
FWIW, the Spoon header does not use the bracket.
Old Sep 16, 2002 | 10:16 PM
ITR#132's Avatar
But I paid for that JDM support bracket
Old Sep 16, 2002 | 10:28 PM
Chris's Avatar
If it was so unnecessary then why did it bind?? and break??
How did that happen?
Old Sep 16, 2002 | 10:35 PM
Mike M's Avatar
Founding Member
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (Chris)
Not many people have broken the bracket
Of Course I think i'm the ONLY one to break the Bracket on my Toda header that connects to the JDM Header Bracket
JDM Header bracket is fine though.
SurferX's Avatar
My bracket broke too but mine was a USDM bracket though. I had the DC JDM header when this happened.
Old Sep 16, 2002 | 11:27 PM
Ibuprofen's Avatar
Old Sep 17, 2002 | 04:22 AM
Hooch'n's Avatar
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (01-0531)
How...........Moves that much?
Old Sep 17, 2002 | 05:42 AM
GM2000ITR's Avatar
New User
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (SurferX)
I've been using my USDM bracket w/ my DC JDM 4:1 for over a year now & it's still in perfect shape! Sorry to hear a bout your bracket difficulties.
Old Sep 17, 2002 | 05:44 AM
DutchITR1689's Avatar
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (95gsrvtec)
Are u guys using the flex bolts with springs?
That could be the cause. Maybe the spring was too tight...
Old Sep 17, 2002 | 08:12 PM
ITR#132's Avatar
TOO much power??? I dont know. This was brought up before and a couple of guys agreed that theirs was starting to tear under the bolt; mines just tore all the way.
Old Sep 17, 2002 | 08:14 PM
Rob :190:'s Avatar
my mugen bracket broke...
onyx00's Avatar
Wow, I better check mine this weekend just in case
Onyx who is hoping to replace his JDM 4-1 with a Toda soon
Old Sep 17, 2002 | 08:16 PM
ITR#132's Avatar
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (DutchITR1689)
Are u guys using the flex bolts with springs?.
Flex bolts? What are they? I used the stock exhaust bolts and springs connected to a Spoon straight pipe (So it wasnt a welding the cat flange problem)
Too tight? There is a stop on the stock header to cat exhaust bolts. You cant make it too tight....Stock US exhaust springs(Dont tell me I need JDM springs)
Old Sep 18, 2002 | 02:09 AM
Art Vandeleigh's Avatar
yes you do, they are made of special material that allows it to conform and blend with the jdm header material of the dc. heheheheh
that sucks man.....i hope you fix it or at least find out why it happened. good luck and may the force be with you
Old Sep 18, 2002 | 06:51 AM
acura_typer's Avatar
Banned
good luck finding another one, I haven't been able to at all for the past 3 months. I was thinking about making my own.
BTW, if its not really needed, why did Honda put it there? Its a support bracket, supports weight of the header so its not all hanging off the flange at the motor.
Old Sep 18, 2002 | 07:15 AM
BERT-O's Avatar
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (acura_typer)
wow, i didn't think there's alot of stress there on the flange.
i'ved gone without a header flange for the past year or so.
wonder what would it fo?
Old Sep 18, 2002 | 08:06 AM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (SANBST)
looks like an easy part to fab....
later
matt
Old Sep 18, 2002 | 08:11 AM
xtrafastcivic's Avatar
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (champITR)
not that many ppl use that bracket.. what kind of exhaust do you have??? maybe the way your exhaust hangs or testpipe/cat....
Old Sep 18, 2002 | 04:57 PM
J Ritt's Avatar
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (XtraFastCRX)
Mine broke off after a year. When it did, it happened at the track (pocono). It was making this terrible ringing noise, that sounded like it was coming from inside the block...I thought my engine was toast...scared the **** out of me. I stuck a long screwdriver down through the headers and applied some pressure...voila...noise was gone...smile came back to my face. Whew. I didn't bother putting one back on...it just helps to stabilize a bit, but I'd say not critical.
Old Sep 18, 2002 | 05:00 PM
B2FiNiTY's Avatar
Default Re: To those with JDM 4-1 headers...Hell to those with JDM headers (J Ritt)
I've heard of a few people breaking theres. Not a rarity.
B0oStnB18C5
Nov 20, 2002 09:23 PM
Toda
Jun 27, 2002 08:45 PM
itr501
May 9, 2002 05:43 PM
princeallure
Mar 11, 2002 08:47 PM
