Transmission & Drivetrain Gearboxes, Differentials, Clutches
96 integra clutch problem please help
Old Aug 11, 2010 | 06:19 PM
TimKing89's Avatar
Default 96 integra clutch problem please help
I just replaced the clutch on my 96 integra and i put a stage 3 6 puck clutch new throw out bearing and pressure plate but for some reason when i try to put it in gear it wont and it grinds reverse and will not even try to go in any other gears and this is my only vehicle need it running asap so any help would be helpful thanks
Old Aug 11, 2010 | 10:54 PM
93h2beg's Avatar
Default Re: 96 integra clutch problem please help
did u put the clutch on correctly? did u disconnect the hydrolic line to the fork? if so did u bleed it? when u put the trans back in did u put the clutch fork in at all? is it on the engine side of the fork?
Old Aug 12, 2010 | 06:46 AM
TimKing89's Avatar
yes i bleed the clutch and what do u mean did u put it in correctly is there a sertai way to put the clutch disk in because i have done a couple clutchs on my old car and it was easy and the fork is in there it is moving when we push on the clutch but it just is not pressing it enough
Old Aug 12, 2010 | 10:32 AM
93h2beg's Avatar
the clutch will physically go in two ways but only work one way. if the hub part of the clutch is facing the motor its in backwards.
SikB
May 16, 2009 03:18 PM
crewdawg88crx
Dec 3, 2008 02:26 PM
ttk3
Jul 20, 2008 04:02 PM
mikeycivic
Jun 4, 2007 05:32 PM
vjace
Jun 28, 2004 02:45 PM
