cam tdc???
i have a 2000civic ex and i did a timing belt change, i didnt do a tdc before i took off the belt, so i did tdc on the crank pully, and soo im stuck with the cam gear? i turn counter clockwise a few times before i tdc it, or does it matter how many times i turn it, or does it just need UP at 12oclock and horz line at cylinder head??
Thanks...
Thanks...
just make sure the bottom end is at tdc. # 1 piston is at tdc. then set the cam gear to the up position, if you're not sure if the cam gear is at tdc there is a small hole in the camshaft that lines up with a hole in the cam cap (the hole is on the first cam cap after the cam gear) put the belt on and tighten to 40 lbs
DMCCOY
12
Jan 9, 2009 08:39 PM
