New Hondata products released
Hondata s200 and V3 Software
Hondata announces the release of a new s-series product line, starting with the s200, and updated V3 software. Also available are additional tune libraries for common engine combinations. For current customers upgrades http://www.hondata.com/v3upgrades.html are available. The s200 is priced the same or lower than the equivalent stage 2/3/4.
s200 http://www.hondata.com/s200.html
The s200 is based on the Stage 2/3/4 system, upgraded for additional reliability and functionality. The s200 is released simultaneously with the updated ROM Editor and HondaLogger software. Major features of the s200 are:
- Surface mount technology for increased durability and reliability.
- Connector and wiring compatible with the Stage 2/3/4.
- Boost and datalogging upgrades via software.
- Improved datalogging speed and reliability.
- Overall rpm limit now set in the ECU ROM.
- Requires ROM Editor V3.0 and HondaLogger V3.0
ROM Editor V3.0 http://www.hondata.com/romeditorv3.html
The latest version of Hondata's tuning software, ROM Editor has been upgraded to support the s200 system, but will continue to support the Stage 2/3/4 systems.
New features:
- More custom tunes built in.
- Improved base fuel maps for larger injectors at part throttle.
- Improved base maps for boost fuel and ignition.
- Program EEPROMs from ROM Editor (Windows NT, 2000 and XP only).
- Support for FJO wideband lambda analog input.
s200 specific features:
Configurable Air Conditioning shutoff.
- VTEC switching changed to use rpm and engine load.
- Non VTEC ECUs better supported.
- Fuel & Ignition tables extended to 11,000 rpm.
- Japanese P08 ECU supported.
- More sensors can be disabled.
- File comments can be saved in the ROM file.
HondaLogger V3.0 http://www.hondata.com/hondalogger.html
Hondata's datalogging software, HondaLogger, has been upgraded as per ROM Editor. Main new features are:
s200 support.
- Up to 50 % faster datalogging speed. Sample rate is now 900-1000 Hz on newer PCs.
- New main windows layout allowing multiple windows to be open simultaneously
http://www.hondata.com/images/hondalogger1.gif .
- More sensors can be datalogged (s200 only).
- Dealer version of HondaLogger can datalog from any s200 system, even if the datalogging option is not enabled on the s200 system.
Downloads
- Hondalogger V3.0 http://www.hondata.com/downloads/hondaloggerv3-0-6.exe
- ROM Editor V3.0 Demohttp://www.hondata.com/downloads/rom...demov3-0-5.exe
- Brochurehttp://www.hondata.com/downloads/brochures200.pdf
[Modified by Hondata, 10:18 PM 9/16/2002]
New features:
s200 support.
Downloads
Let me ask a question here..
Can you break down the difference between the Hondalogger and ROM editor?
From what I gather, the Hondalogger is used only to record information, the editor obviously allows one to edit his/her ECU settings, but does it have it's own datalogging ability, or do you still need to have the Hondalogger to edit?
Upgrade info is available at http://www.hondata.com/v3upgrades.html
The difference between the Hondalogger software and Romeditor is that Hondalogger is just for datalogging (actual readings that your sensors are sending to the ecu) and Romedtor is for modifying rom images (making changes to the timing tables, fuel tables, vtec...etc.)
integra1884
May 17, 2002 09:03 AM
