!!!Help Please!!! Accord 1994 Overheating
Old Aug 10, 2010 | 06:36 PM
faran's Avatar
Default !!!Help Please!!! Accord 1994 Overheating
Honda Accord 1994 is overheating while on a Stop sign or a traffic light Temp Gauage goes to Red Mark as soon as I accelerate, gauge slowly starts coming down.
Bleeded the system 3 times for any air or pocket through bleeder valve and Radiator cap. One interesting thing I have to fill the Reservoir bottle and radiator after almost 2 days as it goes empty but then for almost 2 days no issue of overheating then again reservoir,radiator goes empty while I do not see any visible leaks or coolant leaking.T-stat is fine, if radiator is clogged how can I clean it real good by myself.
Please help and advise with any solutions as I am pulling my hairs no other source of transporatation
Old Aug 10, 2010 | 07:34 PM
HonBeer's Avatar
Default Re: !!!Help Please!!! Accord 1994 Overheating
Check your fans.
Old Aug 10, 2010 | 07:38 PM
TheMuffinMan's Avatar
He knows where you live!
Originally Posted by HonBeer
Check your fans.
Bingo, there was a thread just recently on this within the past week or so.
Check to see if your fans are functioning.
Old Aug 11, 2010 | 07:17 AM
jdadams12's Avatar
Is the A/C on? Even if it doesnt' work, turn it on to get that fan running.
Old Aug 11, 2010 | 09:44 AM
faran's Avatar
Fans are working fine with & w/o AC no issues while i saw coolant leaking close to the exhaust area whAt it could be?
Please help
Old Aug 11, 2010 | 10:00 AM
AndyD's Avatar
I don't think your issue is the fans. I have a '92 Prelude and a '92 Accord. The fans don't work on either and I have never had an issue with over heating. I drove my Prelude that way for 7 years, and I even tracked it without issue.
Does your car run fine besides the overheating?
Your coolant has to be going somewhere. How long has the overheating been happening? If it started recently, check your oil to see if it looks odd.
Old Aug 11, 2010 | 04:08 PM
faran's Avatar
Boss,started week back,oil so far looks fine but car drives tight no issues except Overheating;(
I have seen 2spark plug wires are showing lil bit oil thts it.
Fans do come pleas help;(
Old Aug 11, 2010 | 05:10 PM
holmesnmanny's Avatar
Please help
normally when your car cools when driving it's cause your radiator is being cooled by the air and circulated.
Where exactly is the leak you are seeing?
Old Aug 11, 2010 | 05:14 PM
poorman212's Avatar
Ok, I think you posted this a while back.
"T-stat is good" - Replaced when?
"Coolant leaking close to exhaust"-More info please.
Pressure test showed?
"Fill everything (overflow and rad) and it runs fine for ~2 days then needs more"
Sorry, it is going somewhere. There is UV dye that can be added to the coolant, if you can't see it leaking any where and the other tests show nothing. I think you also posted about replacing hoses and that. Cold leak, leaks when hot? Dye might help find that.
Old Aug 11, 2010 | 05:53 PM
faran's Avatar
Thanks for your reply BRO!
T-Stat is good I have replaced it like 1.5 yrs back.
I think rear end of the Motor as I have seen leaking today precisely beneath the O2 sensor area after 45 min drive during Drive no Overheating.
Yes right after 2 days need more coolant and starts to Overheat.
I think leaks when hot as I kept the Car start today in the morning for 25 min to check leak but no Leak from anywhere.
Heater core, bypass and 2 other small hoses are new, upper, lower radiator hoses are in ok condition.
Normally heats up on a traffic light, stop sign then continue till I start to cry or turn off the car but when I accelerate temp guage starts moving down.
If the radiator is clogged what could be the symptoms??
Pleas help and advise
Old Aug 11, 2010 | 06:22 PM
AndyD's Avatar
Ok. Then the overheating is only due to the leaking coolant.
Check the heater hose that goes from the firewall to the black metal coolant pipe on the back of the engine. It should be on the driver's side on the back of the engine block. Mine came loose one time.
Old Aug 13, 2010 | 06:38 PM
TamyS's Avatar
okies soo i dont really have anything to help you, but i am having the same issue ..... but i can tell you that some of the coolent hoses are hidden under the intake, i had a leak there and it was wayy hard to see .....
on another note ... i wanna know if there is away that somethign like a valve or whatever would stick and not allow the coolent to fun thru the engine.. i have a 94 as well, though only one fan works and the A/C dosnt, it never did sence i got it. i'ma look into fixing it but still didnt have this issue till a while after havieng the car already. soo if someone could say where a valve is that might be getting stuck would be great! thanks Tamy
Old Aug 13, 2010 | 06:42 PM
CRX Si69's Avatar
i would drain the oil and look to see if there is any anti-freeze in there. if there is, your head gasket might be blown, since you did say there was a leak near the exhaust.
Old Aug 13, 2010 | 07:06 PM
HonBeer's Avatar
People dont clean radiators anymore. They are so cheap to buy. Just buy a new one. One for that model and year would be About $80 shipped.
Bugstomper
Jul 27, 2015 02:05 PM
shawn474
Jul 14, 2014 12:04 PM
faran
Aug 7, 2010 07:55 AM
nickhans
Oct 28, 2005 07:46 AM
ocdcivic
Mar 10, 2005 04:50 PM
