D15b7: CEL codes 9 & 10 with video
Old Aug 10, 2010 | 06:22 PM
greenhonda420's Avatar
Default D15b7: CEL codes 9 & 10 with video
this d15b7
sonds like popping out the exhaust
cel codes 9,10(cyp,iat)
not sure how to measure the output current of iat can anyone explain?
it sounds like its out of time only at the back of car, engine sounds fine...not too sure though.
i dont have a timing light to check timing. so i tried to take the hyper tension pulley off (pulley that alternator belt is on) what ever its called, to check the timing that way but couldnt get the pully bolt loose with air gun so i coulnt do that.anways car use to idle perfect until the crank sensor in the dizzy got wired up correctly(used to not rev past 3k)
any suggestions on the problem besides fix the cel codes then go from there.
*watch video plz*
http://www.youtube.com/watch?v=qWKV0V4M2UE[/URL]
Old Aug 10, 2010 | 06:30 PM
Former User's Avatar
Default Re: D15b7: CEL codes 9 & 10 with video
Thread titles MUST be subject specific. As you are relatively new, I edited the title for you this time.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
Fix the CEL code 9 for the CYP sensor inside the distributor first.
Old Aug 10, 2010 | 06:49 PM
will it mess the engine up if i drive it until i can fix the dizzy sensor?
Old Aug 19, 2010 | 07:50 PM
97 civic lsvtec's Avatar
i had the same issue with my car code 9 i replace my ign coil and it fixed the issue
writemealetter
Aug 27, 2017 12:26 PM
cleanazcoupe
Jun 30, 2009 04:35 PM
See Are Ex
Jun 16, 2006 04:58 PM
bad-monkey
Jan 18, 2005 06:41 AM
