do you lose power with a d15 block under a d16 vtec head
Old Aug 10, 2010 | 03:47 PM
tundra2000's Avatar
Default do you lose power with a d15 block under a d16 vtec head
A few months ago i broke the block on my 95 civic ex so i put the d15b7 block under it because i had it laying around, my question is do i lose power by having the d15 block under my d16 head?
Old Aug 10, 2010 | 04:37 PM
D16SiHatch's Avatar
Default Re: do you lose power with a d15 block under a d16 vtec head
maybe a smidge. doubt if you'll notice an appreciable difference though.
Old Aug 10, 2010 | 04:57 PM
Tico Loco's Avatar
Could be about the same or better, the D16z6 head had a smaller chamber volume and better if you use the D16z6 head gasket ( metal ) because it is only about 0.50mm thick versus the D15b7 head gasket ( conventional not metal ) 1.9mm.
With the D16z6 head gasket you can achive about 10:30 C.R. With the D16z6 ECU and the V-tec valve working properly you have like a D15b Vtec (Japan) with more C.R.
asianmario_one
Mar 6, 2007 12:06 PM
JDMTuner4Life
Feb 24, 2007 07:29 AM
dmcclain
Aug 4, 2006 04:53 PM
BoostdRex
Nov 12, 2005 02:10 PM
