Where do I find replacement rubber trim for the 90 EX doors?
The rubber trim/molding that runs along the middle of the door has a crack in the rubber and is leaking rust down the side of my driver's door. Where do I find replacements for this?
the molding may not be the problem. you might have a rusting door skin behind the molding. you'll have to pull the molding off and see. molding may be available aftermarket, but i've never seen it.
http://www.tasauto.com/Product/Browse.aspx?d=1700&p=1
The molding is most definitely the problem. The rubber cracks and allows the mounting plate inside to rust, which then drips down the side of the door through the cracked rubber.
I believe this is the correct part? Thanks for the link.
http://www.tasauto.com/Product/Detai...293&d=1700&p=2
if you don't have the piece yet, wait until it comes in. it should have double sided tape attached already. if not, buy some 3M molding tape. read the instructions and apply to the molding, then apply the molding to the door. Wal-Mart or any parts store will usually have this:
http://www.amazon.com/3M-03609NA-2x5.../dp/B001B0QC3M
rayaman2
Mar 16, 2011 10:15 AM
