F20A in a 91 accord?
Old Aug 10, 2010 | 11:32 AM
TURBOcrx@1.4bar's Avatar
Default F20A in a 91 accord?
Hey everyone i got a accord project iam doing and iam new to the accord tuning setups so all help and imput will be nice. iam going to rebuild my f22a and put a h22vtec head on it. but it will take alot of time and money for that build. so i got a few F20A DOHC engines at my shop and i want to know what is needed to make it run in my accord i know everything bolts up just got to rewire somethin on the coil and dist. just let me know guys thanks
ill get pics of the car up soon i just got a 91 accord wagon that is very clean and it was only $150 with a bad rod bearing.
Old Aug 10, 2010 | 01:15 PM
Default Re: F20A in a 91 accord?
well iam going to do a write up on my progress on this swap with pics and see how it comes along. but if anyone has imput let me know.
Old Aug 10, 2010 | 03:44 PM
ok well iam throwing the f20A swap out the window and i want to put the h22vtec head on the F20A dohc block has anyone done this before? what is involved?
Old Aug 11, 2010 | 07:58 AM
bump anyone?
Old Aug 11, 2010 | 04:35 PM
Ok so i just stayed with the F20a swap and its all done working like a champ except for my cracked exhaust but a dc sports will fix that. everything was bolt on the only 2 things you have to do is 1.change the dist unless you buy a F20 that has the internal coil than its all plug and play.if you dont tho i belive a 91 prelude dist will work. and 2nd you will have to use the ps bracket that comes with the F20. also on most JDM engines they come with a oil cooler between the block and oil filter.you can leave it on like i did. or take it off but than you will have to change the water pipe and plug a hole thats in the block. and the same ecu works fine just adjust the idle skrew on the tb to up the rpm a bit. ive got some pics and vid ill post up in a few min. any questions just ask.
Old Nov 6, 2010 | 08:15 AM
r3dude's Avatar
Hey Man where abouts are you.
I been searching everywhere for parts for a f20A dohc engine .
I have one in my 92 prelude and CANNOT find one for parts anyhere. I snapped a rod and dinged up a piston wen the rod broke.
Think u could part one of ur f20s out for a piston and rod? or a hole motor
let me know.
and as far as the h23 head im pretty sure the h23 head goes on that block no problem. I have a f22b1 sohc 97 accord engine now but it doesnt wire up to the lude.
Im about to put the f20 head on the f22b1 but i seen alot of bad info on here about that.
so if u got parts let me know.
My email is r3davison@hotmail.com
Old Mar 5, 2011 | 07:54 PM
schools94's Avatar
Just curious as to what transmission you are using? I have a prelude with a f20a in it and I believe it has an h22/23 trans behind it now but the syncros are going out on me. So I'm trying to find a diff trans to put in it's place. I like the ratio mine has but I'm up for anything at this point. Any suggestions?
Old Mar 18, 2011 | 12:39 PM
any f/h trans will work same bellhouseing. iam useing the stock f22 tranny. i would go with a Hseries trans.
Old Mar 18, 2011 | 01:12 PM
here is a update the car has been running fine for the past few months. just some new pics to post. and a vid. iam going to try to blow the motor in a few weeks cus i got a h23 iam almost done with and i want to swap it out.
MistaKilla
Jul 28, 2011 06:37 AM
Mft62485
Mar 12, 2009 04:22 PM
91accord1010
Sep 14, 2007 05:14 AM
gumbysix
Acura TL, RL & ZDX
Sep 10, 2005 11:31 AM
