Trans Hitting frame
Old Aug 10, 2010 | 10:32 AM
MattNYC's Avatar
Default Trans Hitting frame
I have innovative mounts and i just dropped an B18B into my 95 EG Hatch. the Transmission is on the frame and im not sure why. all the mounts r in correctly. has anyone ever run into this problem before.
P.S. How Much manual Trans fluid do i have to put into a Bseries trans? i have to go to the dealer for fluid so i want to know before hand.
Old Aug 10, 2010 | 04:53 PM
canadaek's Avatar
Default Re: Trans Hitting frame
no and 3L will be more than enough.
Old Aug 10, 2010 | 05:59 PM
95EG2's Avatar
ur probably the only person who has this problem... i have a b20 with innovative mounts no problem with fitment the mounts have to be wrong or something that doesnt make sense at all... post pic i would like to see...
fill the tranny up untill the fluid seeps out the drain hole
Old Aug 11, 2010 | 04:09 AM
94EG8's Avatar
Seagull Management
Was the car originally an automatic? Did you get an auto to manual upper transmission mount, or did you cut the automatic pocket mount off the passenger's side frame rail and weld on the manual version?
Old Aug 11, 2010 | 04:46 AM
95EG2's Avatar
^^^^ listen to this guy... my friend accord had the problem u have because it was a automatic... he had to order the mount for his H22
Old Aug 11, 2010 | 03:08 PM
MattNYC's Avatar
ok guys thanks for the help guys. i called innovative and i ordered the right mount. i had the regular one. since i did the conversion i need that m/t to a/t mount, which i just ordered. thats a fu***** load off of my mind. i thought i was going to have to cut the frame out some. lol. HT Does it again!! W00T W00T
jdmh22eg2
Transmission & Drivetrain
Jan 4, 2013 03:51 AM
efcivic92
Sep 21, 2009 10:56 AM
the4g4d
Jan 31, 2007 10:20 AM
YEE*MagicEK20kombobomber
Aug 3, 2005 10:08 AM
Strem
Jul 22, 2003 09:30 PM
