Strange suspension?
Well the reason i was asking, i bought the Strange setup with dual damping, but when i installed the rears with the 12" springs and the coilover turned all the way down the car is pretty high in the rear. So i was wondering if people just run the 10" in the rear.
You're going to have to use 12" spring and I would recommend 600-650 lbs spring, don't follow that kg scale. For the fronts you are going to need 10" springs and I would recommend 450lbs, Hypercoil and/or Eibach would be my choice of springs to use.
Silchuki14
Suspension & Brakes
Aug 5, 2008 07:01 AM
