PA: 89 CRX Si w/ B16 and goodies part out!
Old Aug 9, 2010 | 07:45 PM
CRXed's Avatar
Default PA: 89 CRX Si running parts car w/ B16
Edit: No longer parting car out. Selling as a running parts car. You will either need to bring wheels or tow the car as the OEM Si wheels have tires that do not hold air. The front drivers side took a hit and the suspension is pushed back 2 inches.
$2000 take it away!!! PICTURES AT BOTTOM
Seibon carbon fiber ZC hood
Mishimoto radiator hoses
CRX Si lip
JDM half leather seat
Exhaust- Edelbrock 4-2-1 header (severely dented) to stock cat that is welded to a custom made 2.25" catback
Suspension - Koni Yellows and Neuspeed race springs.
Sealed lightweight Odyssey battery has been relocated to lock box with circuit breaker.
Lots of new trim on doors and fender
NEW Fuel pump relay ($70)
NEW Walbro 190lph fuel pump
New AEM SR intake designed for a Del Sol (ghetto I know)
New Silverstar low beams in head lights
Ebay rear strut bar
Box of tons of parts, bulbs, relays, etc.
OBD0 B16A - Installed in 2007
YS1 LSD tranny - occasional 2-3rd grind at high RPM
ECU is chipped and running BRE
(Easy to use tuning program: secondary O2 sensor disabled, launch control, etc)
Burn 1 chip burner and 5 chips included
Hasport mounts, shift linkage
Skunk2 Stage 1 cams
Supertech valve springs and retainers
New OEM Type R LMAs
ARP head studs
Cometic head gasket (stock thickness) done in 2010.
Custom LPC powder coated AEBS intake manifold. This is a freak color and can't be reproduced. Beautiful and I would hang this thing in my room.
LPC powder coated throttle body.
B18 fuel rail for manifold clearance. Shaved it a bit.
Thermal heat shield spacers on throttle body and intake manifold.
Magnecor plug wires
Timing belt and water pump (2007)
Rebuilt JDM OBD0 starter (December 2008)
New distributor and cap (2009, 2008)
FICV, IACV coolant bypassed
VTEC solenoid has been cleaned recently
Brand new Mishimoto racing thermostat
Wiring harness comes with motor. All additional wires involved with tuck come with. (From lock box to distribution block, d. block to relay, alternator to distribution block, VC ground, distribution block, fuse breaker, and fuse breaker to battery.
DOES NOT COME WITH VALVE COVER, WIRE COVER, OIL CAP, OR BREATHER. Those are staying with me.
Disclaimers about motor: Cylinder 3 combustion chamber has marks from spark plug electrode.
Random misfiring on partial throttle. Could be related to tune / lack of secondary O2 / improper idle settings.
There has been a tapping sound since cam install. Took cams out, put back to stock, still tapped. Rebuild head with cams, retainers, valve springs, LMA's..still tapped.
It has been tapping for years and nothing has happened. No valve damage, no idea what it is.
Slight coolant leak out of front left corner of head gasket area. Seems to be a common issue?
Taken 4/3, more photos available upon request
Old Aug 10, 2010 | 09:21 AM
CRXed's Avatar
Default Re: PA: 89 CRX Si w/ B16 and goodies part out!
Taking more pictures this weekend. Let me know if there is anything you would like a picture of!
Old Aug 10, 2010 | 10:27 AM
TJChad's Avatar
Might be definately interested in your hood. Post up alot of good pictures and once I finish rebuilding my DD truck's tranny i'll be talking with you. It's a true Seibon correct? Still have the badge and hood pins aren't required?
Old Aug 10, 2010 | 02:22 PM
CRXed's Avatar
Yes it is true Seibon with the badge. No hood pins are needed.
Old Aug 10, 2010 | 04:29 PM
waspcrx19's Avatar
Still have them Konis and springs!? how much to ship to 93906? Gimme a deal!
Old Aug 10, 2010 | 07:02 PM
mgs1098's Avatar
PM me a price shipped on the nuespeed bar. Shipping to VA, 23703. May also want the wiper arms.
Alan
Old Aug 11, 2010 | 02:26 PM
MRN1120's Avatar
I need all of the front interior. Lmk Pm sent
Old Aug 11, 2010 | 02:56 PM
cantresjr's Avatar
I'm interested in: Window deflectors, B pillar trim for both doors, wiper arms, Upper trim for the tail gate(black one that is near the roof ) and side mouldings. shipped to 33029. would buy hood if shipping was reasonable. lmk
Old Aug 15, 2010 | 02:53 PM
CRXed's Avatar
Bump
Old Aug 19, 2010 | 10:24 PM
CRXed's Avatar
Bump, taking pictures this weekend. Let me know if you need a pic.
Old Sep 13, 2010 | 08:08 PM
CRXed's Avatar
Some more pictures up. Someone take the shell. $500 with suspension and interior parts (no seats)
Engine will be out soon and cleaned up.
Old Sep 13, 2010 | 08:17 PM
kid-honda's Avatar
If the passenger fender is oem and in good shape ill take that in a package with the strut bar.
Old Sep 14, 2010 | 07:41 PM
CRXed's Avatar
I can't verify that either fender is OEM.
Old Sep 17, 2010 | 10:45 AM
Junkyard's Avatar
Pm'd
Old Sep 17, 2010 | 05:53 PM
CRXed's Avatar
Responded. I'd love for someone to take the shell of the car....really cheap....
Old Sep 22, 2010 | 02:16 AM
ChR1sCRX's Avatar
I'll take the shell and I'm local - Sent you a few PMs.
I know I'm a new member here but I'm a real person with a real job and real money ** Shameless plug for my Sportbike shop* www.msrecycle.com
I'm the owner and senior body/painter.
Old Feb 25, 2011 | 05:07 PM
CRXed's Avatar
Bump! Car was put back together for winter duty and everything is for sale again!
Old Feb 26, 2011 | 09:36 AM
cantresjr's Avatar
do you have the LSD tranny? how about the Steering wheel?
Old Feb 26, 2011 | 09:39 AM
vtechjunkie's Avatar
pm'd
Old Feb 26, 2011 | 10:42 AM
sh!ft's Avatar
Who the fack changed my title?!
would you ship the hood??
Old Feb 26, 2011 | 11:55 AM
mgs1098's Avatar
Email sent on the headlights and radiator hoses.
Alan
Old Feb 26, 2011 | 12:12 PM
CRXed's Avatar
I will not ship the hood, sorry. Pick up only
Old Feb 26, 2011 | 02:32 PM
oasis24-7's Avatar
is there any rust or bondo on the shell?
Old Feb 26, 2011 | 02:47 PM
BWFL's Avatar
"Neuspeed front strut bar (powder coated graphite, lots of grind marks underneath coating..but it definitely tightened up the front end) $60 shipped"
Does that count for shipping to Canada? Saskatchewan specifically
Old Feb 26, 2011 | 06:44 PM
1990CRXSIJDMEF8's Avatar
bump
