limp mode or no????
Old Aug 9, 2010 | 07:11 PM
Godspeedmj's Avatar
Default limp mode or no????
my 94 civic wont rev past 3100 rpms acts like its hitting rev limit, throwing a cel code 4 but i replaced the dizzy and even tried different ecu and checked all wiring still nothing. today i was cleaning the intake manifold with tb cleaner with the car on and when i spray it in and push the throttle it revs to just under 6k....so is it limp mode or maybe low fuel pressure or something like that? tell me your input on what u think? thanks
Old Aug 9, 2010 | 07:24 PM
Godspeedmj's Avatar
Default Re: limp mode or no????
any1?
Old Aug 9, 2010 | 07:42 PM
Godspeedmj's Avatar
ttt
Old Aug 9, 2010 | 08:04 PM
Former User's Avatar
Still have code 4 or any other codes?
Old Aug 9, 2010 | 08:08 PM
Godspeedmj's Avatar
yeah code 4 only
Old Aug 9, 2010 | 08:10 PM
You must fix code 4 before you do anything else. Check the two CKP sensor wires that run between the distributor plug and ECU for an open or short.
Old Aug 9, 2010 | 08:15 PM
Godspeedmj's Avatar
i did i check all wiring and grounds tried different dizzys even took the car to a shop and they said replace the dizzy but i already had. when the car is warm it idles at 500 rpm barley stays on....
Old Aug 9, 2010 | 08:17 PM
Did you check the wires with a digital multimeter? If not, that's what needs to be done. You can't find most wire problems by visual inspection. Put all of your energy into fixing code 4.
Old Aug 9, 2010 | 08:18 PM
Godspeedmj's Avatar
even tried different ecu's but same code. when car is on the 2nd click before it starts no code only when i start the car does the cel come on. turn off the car and back to 2nd click and no code everytime
Old Aug 9, 2010 | 08:19 PM
Test the CKP wires properly.
Old Aug 9, 2010 | 08:20 PM
Godspeedmj's Avatar
yes i bought a digital multimeter and they were all around 700
Old Aug 9, 2010 | 08:24 PM
700 Ohms? What is "they' and what specific tests did you do? Give details.
Old Aug 9, 2010 | 08:25 PM
Godspeedmj's Avatar
ill have a shop test em cuze i get the same outcome everytime i check.
Old Aug 9, 2010 | 08:30 PM
Suit yourself. But you have a multimeter and the tests are pretty easy to do. Save some money and learn to do them yourself.
Old Aug 9, 2010 | 08:33 PM
Godspeedmj's Avatar
yes ohms and i did the resistance and continuity test
Old Aug 9, 2010 | 08:35 PM
Godspeedmj's Avatar
i know how to do em but the come out good everytime even on the ecu side
Old Aug 9, 2010 | 08:37 PM
Godspeedmj's Avatar
well thanks ronJ for ur input ill keep working on it
Old Aug 9, 2010 | 08:41 PM
Were your tests on the distributor sensor itself inside the distributor? Because that's where you should measure 700 Ohms of resistance. I am saying that you need to test the two CKP wires that run between the ECU and distributor plug. For each wire, you need to run a continuity test to look for an open and a continuity to body ground test to look for a short.
Old Aug 11, 2010 | 08:12 AM
Godspeedmj's Avatar
ttt
Old Aug 11, 2010 | 09:10 AM
Godspeedmj's Avatar
the car idles a lil bit better now that the manifold is a lil bit cleaner
Old Aug 12, 2010 | 01:22 PM
Godspeedmj's Avatar
so does any1 think its in limp mode?
ahthisguyhere
Mar 12, 2007 06:40 PM
tgh22a
11
Apr 17, 2006 03:56 PM
SETI20
Jul 10, 2004 06:44 AM
STREETWERKZ
Jun 23, 2004 01:17 PM
GuyInASpeedo
14
Sep 24, 2003 07:34 AM
