b18b swap in a 92 cx???
Old Sep 16, 2002 | 07:53 PM
DOHCarp's Avatar
Default b18b swap in a 92 cx???
Hey I am ready to do a swap and I was wondering what major issues i will face.
I currently have a 95 b18b1 with tranny, axels, shift linkage, ECU, mounts, and wire harness.
Will the 95 integra axels bolt right into the cx assembly?
any other issues you can think of that I will have to face. thanks a ton!!!
Old Sep 17, 2002 | 03:15 AM
HybridHatchC1's Avatar
Default Re: b18b swap in a 92 cx??? (DOHCarp)
axles and everything will bolt up, i think you will have to add 2 wires or somthing like that for a 4 wire 02 sensor
Old Sep 17, 2002 | 04:02 AM
DOHCarp's Avatar
Default Re: b18b swap in a 92 cx??? (Civ-JDM)
thanks!!
Old Sep 17, 2002 | 05:24 AM
Grimm's Avatar
you'll probably have to lengthen some wires as well. the biggest pain is probably the rear mount try getting the passsenger side in then the rear.
Old Sep 20, 2002 | 06:33 PM
Solid Alibye's Avatar
ummm... only other suggestions is get a LS throttle cable, and LS upper and lower rad hoses. They might be a BIT big for the Civic rad, so just get 2 of those screw type close clams and just camp them down tight and you'll be ok.
BTW; which mounts do you have?
Old Sep 21, 2002 | 05:26 AM
DOHCarp's Avatar
Default Re: b18b swap in a 92 cx??? (Solid Alibye)
I have the stock LS mounts, and I was told to get 99-00 SI rad hoses. Which hoses do you think I should get, the ls or the si...thanks for all the help...I might get this thing started today, I hope!!!
Old Sep 21, 2002 | 09:32 AM
jmm96gsr's Avatar
both rad. hoses will work...get which ever set is cheaper
Old Sep 24, 2002 | 11:01 PM
JMX's Avatar
JMX
Default Re: b18b swap in a 92 cx??? (jmm96gsr)
do u have to change all the mounts out for this swap......my friend and i are currently researching doing an LS swap for his 94 cx
Old Sep 25, 2002 | 07:09 AM
g_man80's Avatar
Default Re: b18b swap in a 92 cx??? (jmx2323)
All the mounts from the LS should be used except the pass. side top tranny mount, which can be retained from the civic.
Also, retain the civic cross member rubber mount on the rear mount, the civic rubber mount that connects to the driver front mount (AC mount) from the LS, and lastly retain the civic rubber mount for the pass. front mount.
[Modified by g_man80, 11:10 AM 9/25/2002]
95CXSLEEPER
Jun 28, 2004 01:34 AM
civic95hatch
Jun 26, 2004 04:36 PM
CivilizedCiv
Feb 25, 2004 09:20 AM
