Honda Accord - Paint Near Wheel Rusting
Old Aug 9, 2010 | 03:41 PM
Kazeari's Avatar
Default Honda Accord - Paint Near Wheel Rusting
Hello All,
I own a 1993 honda accord and the paint near the wheel has started rusting and I've only recently noticed. You can see from the pictures attached below:
Is there any special way to patch it up to the rust part? Am I able to do it myself? If so, is it a relatively easy task to do? Thanks for your help.
Left Side:
Right Side:
Old Aug 10, 2010 | 10:19 AM
sgraham01's Avatar
Default Re: Honda Accord - Paint Near Wheel Rusting
let me guess: you live where it snows. rust in those areas is usually coming from the back side of the panel due to road salt corrosion and can't be covered up. the rust will have to be cut out and the panel will have to be patched.
Old Aug 10, 2010 | 10:45 AM
Kazeari's Avatar
You're right on the spot, how easy is this patching processes?
Or should I should find an auto shop that does it?
Old Aug 10, 2010 | 11:03 AM
chikin pickle's Avatar
My understanding of the process here is that the rusted metal is cut/sanded/ or otherwise removed. Then a metal patch is welded or otherwise adhered to the backside of said panel, and the hole through the panel is filled with body filler/bondo or whatever you would like to cal it. Then sanded, and it is ready to paint.
Old Aug 10, 2010 | 11:23 AM
sgraham01's Avatar
if you've never done body work, stay away from it. the paint will have to be ground off and the panel cut to expose the "actual" rusted out area (it's much larger than it looks since it's on the back side.) the patch panel will have to be welded in very carefully.
link:
http://www.tasauto.com/Product/Browse.aspx?d=1659&p=1
you can use the entire panel or cut off what you need.
Old Aug 10, 2010 | 11:28 AM
Kazeari's Avatar
link:
Is it easy to install the panel? I will need to repaint it right? With the primer and top coat?
Should I just get an autoshop to work on it? How much do you think it would cost? parts and labor?
Old Aug 10, 2010 | 11:34 AM
sgraham01's Avatar
by your asking if it's easy, i assume you have never done it. It's fairly complicated to cut the original panel and make the new patch fit correctly. once you have done that, it has to be tack welded, ground, filled, sanded, primed, sanded, sealed, and top coated. entire quarter panel will have to be painted along with the rear door blended to match it. you would be best off having it done at a shop.
probably $500-700 per side as a wild guess. just get estimates from a few shops. usually free.
Old Mar 21, 2011 | 09:47 AM
n20capri's Avatar
Old thread I know...I keep seeing links to 90-93 Accord quarter panel patch panels but they are all for sedans. However, I have a 2 door. My rust is in the same typical spot - back part of quarter panel near the bumper cover...will that section of the "sedan" patch panels work on my 2-door?
http://www.tasauto.com/Product/Detai...800&d=1659&p=1
http://www.rustrepair.com/part_numbers.htm?pt=2119054R
Car guy all my life - I race Fords but my old standby daily driver is a 92 Accord! 240k miles and runs strong as ever - all stock. It's time to freshen up the outside and I need to tackle this rust first.
Thanks for the help,
Mike
JayPNation44
Paint and Body
Feb 3, 2016 09:25 PM
tropicola
Paint and Body
Jul 30, 2012 10:11 AM
Delano5050
Jan 8, 2007 06:44 PM
dtamminx
Jun 28, 2002 07:21 PM
