Noises
I get this grinding/rubbing sound when i turn right and only right. the sound is louder when the car is at higher speeds what could this be? also, when braking my steering wheel would shake. i changed the rotors and that seem to work for a couple weeks and now its back. are they related? i drive a 91 si hatch. thanks!
Check your dust shields behind your rotors. they might be rubbing. it happens all the time, just bend them back away from the rotors. While your under there, make sure all of your bolts are tight just in case
