Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2005 MDX Belt whistles/chirps @73000 miles
Old Aug 9, 2010 | 03:18 AM
romicva's Avatar
Icon2 2005 MDX Belt whistles/chirps @73000 miles
1 It is not a very loud whistle/chirp
2 Only happens on a cold start up
3 Lasts about 10 min only.
4 Belt has no cracks, no threading on the edges.
5 Auto-tensioner indicator is right in the middle of the proper range.
Guys, I’d be grateful for any ideas in troubleshooting this whistle.
Old Aug 13, 2010 | 01:56 AM
Duane_in_Japan's Avatar
Default Re: 2005 MDX Belt whistles/chirps @73000 miles
Put a quality belt on it and forget it.
Old Aug 17, 2010 | 11:43 AM
mattliston's Avatar
typical of 70k+ miles
old belts make nosie when cold. as they age, they start to harden up slightly
I would buy a new belt if it bothers you, but upon inspection of belt and seeing no damage, its fine to use for a while longer.
If you recently had the belt adjusted, its a bit loose.
Old Aug 17, 2010 | 12:16 PM
romicva's Avatar
thank you for your suggestions.
Old Aug 17, 2010 | 01:12 PM
TTIWWOP's Avatar
Tell-tale sign of low blinker fluid.
Old Aug 18, 2010 | 04:58 AM
NDNV's Avatar
TSB for Chirp from the Timing Belt: http://techinfo.honda.com/Rjanisis/pubs/SB/b08-031.PDF
The idler pulley mounting surface is tilted, causing the
edge of the timing belt to rub against the side of the
drive pulley (gear).
Old Oct 6, 2010 | 11:07 AM
taz138722004's Avatar
Old Oct 6, 2010 | 11:12 AM
I had a similar noise from the belts on my 05 Pilot. Bought a new belt from honda and put it on it still was there. I next removed the belt and spun all the pullies to make sure they were spinning freely. I discoverd the alternator bearing was the problem. it could be and of the pullies making the noise hope this helps
phat00civic
Mar 7, 2012 06:30 AM
96civ06
Jul 4, 2006 08:28 PM
D16z6PN
Apr 2, 2006 09:28 AM
vinuneuro
Oct 7, 2005 09:11 PM
TodaSi
Jul 16, 2002 03:06 PM
