auto to manual 97 civic parts list please
Old Aug 8, 2010 | 05:35 PM
shortstopNE's Avatar
Default auto to manual 97 civic parts list please
I was going to just fix my auto dx but came across parts and in the right spot right time etc...down fall is it will be a manual y7 swap until I get more money. Car is already at the swapping point.
I have from a 97 hx manual
engine harness (its vtec but I'll still use it for the reverse lights problem)
clutch master/slave cylinders
pedal assembly
center console
manual cluster
have a p75 ecu, will this work?
from my y7 swap i got a deal on
manual y7 motor (not sure if anything sensor wise is different then auto)
manual y7 tranny
clutch/flywheel
shift linkage
need new cv shafts, these are shot
came with stock ecu but it happens to be from a 99 00 so I dont think i can use it.
I already swapped distributors from my bad motor because I noticed the pin out clip was different.
Also was wondering if the tranny mount is different
Give me your input please and thanks!
Old Aug 8, 2010 | 05:39 PM
Default Re: auto to manual 97 civic parts list please
http://www.hondacivicforum.com/forum...ad.php?t=57324
saw this, looks like i can use my stock mount but i need shifter bushings?
Old Aug 8, 2010 | 07:54 PM
Xxcivic97xX's Avatar
are you asking what they are or if you need them cause yes you do need them. you can probably just find them at a advanced auto parts.
Old Aug 9, 2010 | 05:37 AM
apexi_rsx's Avatar
you dont need a center console thier both the same auto and manual. u just put a manual boot on ur auto one.
Jackie Wallace
Transmission & Drivetrain
Mar 10, 2013 04:23 PM
96_bhr
Oct 15, 2007 02:16 PM
MetalHead4454
Sep 11, 2005 09:23 PM
tegra33
Sep 23, 2004 08:07 PM
95civic17
Jul 26, 2002 04:34 AM
