headlights problem?
Old Aug 8, 2010 | 05:35 PM
crx_underground's Avatar
Default headlights problem?
hi i have a crx 1988 si and the passenger headlight stopped working suddently. There is 12v but when you put the light on the connector voltage drop to 0. the fuse is ok .
What does control headlights do it have relay anywhere because I don't know what is the problem thanks
Old Aug 8, 2010 | 06:19 PM
D16SiHatch's Avatar
Default Re: headlights problem?
so you've actually tried to install a new bulb right?
Old Aug 9, 2010 | 09:50 AM
yes but there is no change
Old Aug 9, 2010 | 10:35 AM
Former User's Avatar
This statement is confusing. Does or doesn't the headlight connector get battery voltage? Please clarify. Have you checked the ground wire?
Old Aug 10, 2010 | 08:56 AM
yes there is the battery voltage indicated on headlight connector when there is no headlight on it but when light is inserted it appear 0vDC and light doesn't light up thanks
Old Aug 10, 2010 | 09:08 AM
Sounds like a bad connector. Where exactly are you checking for voltage in these two different tests? From different or identical locations in the hot wire?
Old Aug 10, 2010 | 09:51 AM
TJChad's Avatar
are you saying that it has 12V based on a test light or a DMM?
pliskin679
Jan 27, 2013 03:40 PM
thecruzs2007@yahoo.com
Sep 12, 2009 11:02 PM
bopbop93030
Feb 10, 2008 12:49 PM
