Integra front LCA's fit EK?
Old Aug 8, 2010 | 02:35 PM
HondaPartsHero's Avatar
Technical Hero
Default Integra front LCA's fit EK?
I've search a lot trying to find an answer to this. The link in the faq that has the information on sway bars is very helpful but doesn't answer my question. I realize the easiest way to add sway bars to the front of my 96 DX hatch is to just get the EX/HX front LCA's but I'm doing this the junkyard pull a part way and currently they only have one 96 LX civic, but they do have 3 94-99 Integra LS's. Will the front LCA's from these integra fit my 96 hatch and allow me to run the LS front sway bar? If they do fit will I need the integra forks as well? What end links to use (EX/HX or the LS's)? Thanks.
Old Aug 8, 2010 | 03:38 PM
Technical Hero
Default Re: Integra front LCA's fit EK?
bump
Old Aug 8, 2010 | 07:33 PM
hawjboi's Avatar
the lca will fit as well as the sway bar...only problem is that the sway bar will sit below the lca and not on top of the lca...you will need to get an ex/si sway bar and also i do not know how the endlinks will match to the integra lca...they might be different but i'm not too sure on that...
HondaPartsHero
Suspension & Brakes
23
Aug 11, 2010 05:52 PM
Leady
Apr 10, 2010 12:47 PM
3Rd GeAr PuLl
May 28, 2007 06:45 AM
MugenManR
13
Feb 22, 2007 09:02 PM
eklum
Jan 21, 2006 05:45 PM
