speed sensor
Old Aug 7, 2010 | 03:54 PM
James_Starks's Avatar
Default speed sensor
hi i have a 94 civic it as 16" rims that have 205/50/16 do i need to change the speed sensor to get the correct speed or is the diamiter of the stock wheels close enough that it wont matter thanks
Old Aug 7, 2010 | 03:59 PM
D16SiHatch's Avatar
Default Re: speed sensor
should be running 45 sidewall on 16's, but 50 is still fine. it might affect your speedo a little but i wouldn't worry about it. the vss's are not adjustable anyway.
Old Aug 7, 2010 | 04:53 PM
thanks for the info on the speedo and will the 50 on the sidewalls make it rub alot or is an issue of handling
Old Aug 7, 2010 | 07:51 PM
TheStig187's Avatar
IT WONT MAKE A RUB ITS JUST THAT WHEN U GET A LARGER DIAMETER RIM U WANT GET A LOWER PROFILE TIRE,
Old Aug 7, 2010 | 11:32 PM
D16SiHatch's Avatar
shouldn't be a problem unless you've lowered your car a huge amount
fcm
Nov 4, 2014 05:32 PM
96GSRcx
May 15, 2007 05:21 AM
spicoli
Jul 20, 2004 08:19 PM
austrian type-R
Jul 10, 2002 07:37 AM
