What type of Lug Nuts for Civic Si Rims ???
juss go to autozone or something and ask for honda civic lugnuts. all the same. those are oem wheels soo its not like you need tuner lugs like i have on my enkeis.
Do you know what acorn lug nuts refers to? Acorn refers to
Tapered / Conical.
Most all Honda lug nuts are Ball Centric / Round.
You are giving out wrong information. And wrong lug nuts could be fatal.
I'm done arguing,your right.I'm wrong,OP if you want a different color get NSX lug nuts and if you knew what lug nuts to use,why ask?
Read the whole post.
I didn't know when i first got the rims.
I was hoping someone on here knew.
I went to Big-O and the Manager told me most all Honda's are Ball Centric / Roumd.
Then I did some more research and found out the same thing.
Maybe others should do the same, instead of just quessing.
I did use synthetic vtec fluid on the threads
I am using Si wheels on my Civic. When I bought the wheels, I just went to Pep Boys and bought McGuard oem lugs for Honda's. Thats it. Never had a problem. Good luck
acorns have a rounded, ball-like shape. acorn style lugnuts are not tapered/cone-shaped, they're rounded LIKE AN ACORN!
those wheels also came on Civic EX in the early 2000's
I said he can use ACORN STYLE lug nuts,and he took it as use acorn lug nuts.Learn how to read and spell,and next time ask a proper question.You asked what type of lug nuts to use between flat,tapered,and acorn.You didn't ask any other kind,it's pretty obvious the correct ones to use are OEM.
