Wierd TPS bolts.. How Do I remove them?
Old Aug 7, 2010 | 10:34 AM
Evasion's Avatar
Default Wierd TPS bolts.. How Do I remove them?
Hey guys, just purchased a used throttle body. All it needs is a new TPS, but I can't get the old one off to put the new one on. Any Ideas?
Old Aug 9, 2010 | 09:07 AM
Evasion's Avatar
Default Re: Wierd TPS bolts.. How Do I remove them?
If any body else comes across the same problem, take a Dremel and cut a slot into the top of the screws. Then, just use a flat head screw driver to remove the screw from the slot you cut. Easy
Old Aug 10, 2010 | 02:15 AM
hawaiiancb74's Avatar
lol damn thing thing was beat up
Old Aug 10, 2010 | 05:14 AM
turboteg2nv's Avatar
lol I've used that trick once or twice
Old Aug 10, 2010 | 05:22 AM
Chef Andre's Avatar
HT's TOP CHEF
LOL I actually used this trick last night. Got a new Skink2 74mm TB.
Old Aug 17, 2010 | 07:24 PM
PearlZ1's Avatar
Or if you don't want to have to cut anything, you can also try using a vice grip. I've used both techniques successfully.
Old Aug 20, 2010 | 10:37 AM
Both options will pretty much destroy the nut/bolt and will render them unusable for future use, so keep that in mind.
Old Aug 20, 2010 | 05:37 PM
PearlZ1's Avatar
Not if you do it right. I'm still using the original bolts even after trying both methods. I would say the vice grip method will probably be the safer option if you're not as skilled with the dremel though.
mindless head
May 31, 2015 07:38 PM
NvBiker1
Apr 8, 2013 06:32 AM
gsr98teg
Feb 18, 2004 04:07 PM
htownteg
Jan 24, 2004 08:48 AM
serious
10
Sep 17, 2002 10:14 PM
