transmission flush.
Old Aug 6, 2010 | 09:34 PM
joe_accord23's Avatar
Default transmission flush.
i have a 5spd gearbox transmission on my accord. my question is how do i change the fluid? n wut type of fluid to use? wuld royal purple fluid word? on my manual it says it uses motor oil in the transmission help me!
Old Aug 7, 2010 | 12:44 PM
holmesnmanny's Avatar
Default Re: transmission flush.
The holes are visible when you take off the front right wheel. The filler bolt is a 17mm bolt that is just above and to the left of the drain bolt which is just a 3/8 drive bolt. I bought a plastic oil holding funnel and tube thing at Walmart in the automotive section for a few bucks that I used to fill up my transmission. You fill up a plastic piece that you can sit in the engine bay and then unlock the locking piece and it'll drain the oil through the tube into the fitting that you sit inside the transmission.
Old Aug 7, 2010 | 06:21 PM
thnx so its specifically for the transmission?...sounds good, and wut type of oil do i use? motor oil? royal purple trans? lemme kno plz
Old Aug 7, 2010 | 10:40 PM
Need to know exactly what kind of car you have, I forgot to ask in my first reply.
Old Aug 7, 2010 | 10:49 PM
There's a website for a local parts shop that gives good specs for most cars.
http://www.alliedautostores.com/Cata...logSubCat.aspx
Just put in your car and year and click on View Specifications at the top right.
Old Aug 7, 2010 | 11:07 PM
bseriescrxsi's Avatar
ive been using gear oil in my 5 spd trans...cant remember the verocity though....
Old Aug 8, 2010 | 01:56 PM
nus_dogg's Avatar
You can go with Amsoil GM Synchromesh or just go with Honda MTF.
Old Aug 9, 2010 | 04:37 PM
thnx alot u guys, i love this forum!
aznromeo4u
Feb 24, 2015 02:52 PM
platanodom
Aug 8, 2007 05:10 PM
GsrTurboCRX88
19
Nov 21, 2006 06:12 PM
shai x boi racer
Jan 25, 2005 06:45 PM
dcrbin22
Sep 15, 2004 10:38 AM
