D16z6 swap questions
I'm considering doing a swap with this engine and I was wondering how difficult the swap would be if I got the entire engine, harness, and ecu if someone could give me like a mini write up I'd appreciate it a lot
is the swap going into a crx? i just put one of these motors in my 91 crx si and it was fairly simple.....
if you have a d16z6 motor just put it in dont use the harness for the d16z6 motor use yours thats in the car change the fuel injector clips to the obd1 style by pulling the rubber out of the back and sticking a pointy pick down in the injector clips to get the wires out... then just get a obd 0 to obd 1 jumper harness from rywire it wil save you so much greif and a p28 ecu and ur set... if you live closer to delaware i would help
dpfi to mpfi conversion
http://hondaswap.com/swap-articles/d...writeup-49557/
then
get yourself a p28, obd0-1 ecu jumper, 4 wire o2, obd1 dizzy, and dizzy adapter.
you have the option of getting this also. would take care of everything besides the dizzy and ecu
http://rywire.com/store/8891-crxcivi...4676b43f39c287
then
streetsold6teeny8
Dec 17, 2007 05:24 PM
mamaboy
19
Jan 23, 2004 06:43 AM
