Need Help Figuring out: DIY 5 Lug Conversion
Old Aug 6, 2010 | 05:34 PM
xlasianizelx's Avatar
Default Need Help Figuring out: DIY 5 Lug Conversion
Trying to ghetto rig a 5 lug conversion... just wondering if the itr knuckles, integra knuckles and civic knuckles are the same?....
questions:
1: possible to just buy itr 5 lug hubs and press it into my factory knuckles
2: rear hub pressed into my factory trailing arms.
3: rear caliper same size as factory rear disc brakes
4. parts list if possible..
Old Aug 6, 2010 | 05:55 PM
canadaek's Avatar
Default Re: Need Help Figuring out: DIY 5 Lug Conversion
what year itr Hubs some have 36mm hub some are 32mm i think and what year is your car do you currantly have rear disk ? rear hub is bolted on not pressed on
Old Jan 13, 2011 | 05:54 PM
Reamos's Avatar
hello, i'm new to this site, i need help from the pros ASAP.
i have a honda civic hatchback Ek3 99-00 D15Z4
i bought ITR 98-spec complete 5 lug set up
we are trying to work these parts in my car.
so far we realized that the ITR is 36mm and my axle is 32mm
we tried CRv spindles, no luck
even ITR 96 spindles - which are 4 lug but we wouldve drilled 5 lug
sorry if this is all BS, but this is what i have been told by my mechanic..
anyways, the crv and the itr 96 dint work ( that is we tried using the wheel hub and bearing.
i do not know what else to do, rebuild axles? how do i do this?
or will a CTR wheel hub and bearing work for my 32mm axles to work?
i apologize for asking on someone else post but i have not yet been able to create a new post.
please help thanks all
tysonlifemv
Oct 30, 2009 09:25 AM
DeMonICRSX
Mar 24, 2009 09:03 AM
jdmdikk
12
Nov 30, 2008 06:31 AM
go2sleep
Apr 14, 2005 12:54 PM
KIWI
Sep 15, 2004 12:21 PM
