FS/FT: MN accord w/built h22 62/62 turbo, 10 point rollcage
Looking to move back to Miami and want to sell this so it doesnt sit and collect dust. If you know this car it made 604whp back in 2005 and sat and slowly got parted out. I purchased it last year and had the motor rebuilt, new transmission, new turbo kit, new computer, injectors, tires, axle etc etc etc around 500 miles on parts.
1993 accord ex 175k miles on body
Price- $8000 or trade
Location- Close to Minneapolis
Contact- PM
Mod list I can think of-
JDM H22
darton sleeves
.20 over JE pistons
Eagle rods
ACL race bearings
ARP head studs
upgraded oil pump gear
head rebuilt(new valve seals, resurfaced, valves checked etc)
All new OEM gaskets throughout motor(head gasket also copper spray)
AEM cam gears
AEM fuel rail
AEM 5 bar map sensor
partial wire tucked
modified stock intake manifold
Vented valve cover
aeromotive FPR
Dual walbro 255 in tank fuel pumps
Precision 1200cc injectors
aluminum radiator
new thermostat
new radiator hoses
Precision T4 62/62 turbo
Custom T4 turbo manifold
Tial 44mm wastegate
custom 2.5 inch intercooler pipeing
Greddy type S bov
3 inch to muffler to 4 inch exhaust to dump before gas tank
Modified motor mounts with custom solid front mount
Custom short shifter
H23 transmission with OBX LSD rebuilt with better hardware
p72 with Neptune Demon RTP and boost solenoid
AEM wideband
Autometer water temp
Autometer boost
Autometer oil pressure
Autometer large tach
hard wired radar detector
MSD ignition
MSD blaster 2 coil
NGK spark plug wires
Custom 10 point roll cage
Custom aluminum door panels
race seats
5 point harness's
Viper pager car alarm
Tokiko struts with coilovers
upgraded large sway bars and end links
Konig 15" rims
225/50/15 mickey thompson drag radials
stock size good years in back
Drilled/slotted rotors all around
ABS removed
z3 fenders
m3 mirrors
Also 4 stock 94+ accord aluminum rims with 2 tires included
H22 transmission that said to grind into 2nd and 4th included
Other random parts I have will come with car
Tons of custom parts not listed and time spent on car, any questions feel free to ask, more pictures can be posted just ask.
Car is only running a wastegate tune on e85 on 10psi making 391whp and 310wtq, built car to make 550whp on e85 reliably, just needs to go back on the dyno and turn up the boost and fine tune. car is very streetable as is, I can also tow dolly this car to you if serious.
Bad-?
Horn doesnt work(aftermarket steering wheel)
Front signal lights dont work
alittle rust spot on drivers rear qtr panel
Hole in hood due to manifold fitment(have cover that needs to be rivited on still)
Car is dirty in pics, and needs to be cleaned out I know, will be done soon.
Contact- PM
JDM H22
darton sleeves
.20 over JE pistons
Eagle rods
ACL race bearings
ARP head studs
AEM cam gears
AEM fuel rail
partial wire tucked
Vented valve cover
aeromotive FPR
aluminum radiator
new thermostat
new radiator hoses
Tial 44mm wastegate
Greddy type S bov
AEM wideband
Autometer boost
MSD ignition
MSD blaster 2 coil
race seats
5 point harness's
Konig 15" rims
ABS removed
z3 fenders
m3 mirrors
Bad-?
Thanks guys, it is a lot of fun to drive
Im really only looking for trades that run/drive and something I could drive to FL so no projects unless there is a good amount of cash on top.
Sordz
Jun 11, 2012 10:44 AM
BoostThisMS
Jun 16, 2010 04:07 PM
