FS/FT 1989 240SX Fully built SR20 .40 over gt28 412hp/19
THROW ME ALL TRADES U GOT ? OR SELLING CHEEP! not practicall car for me!
608-290-8514
I have done all of the following within a month,.
ALL BRAND SPANKING NEW!
alternator
starter
coils
full tune up
all fluids flushed changed
rear struts bushings
cracker moon roof
windshield
enthalpy ecu /chip
300zx maf replace USED not new.
injectors
pump
fuel filter
rockerstoppers
all added up and im coming out even if car is sold, im lookign fro something more suitabole were i live, wrx,2.5rs,tsi,gsx, or bmw e36 e46 etc.
or cash offer. 6k
Engine:
Stock block bored .040" or 1mm over stock
Probe Industries SRS Forged pistons, 10.5:1 CR
Eagle H-Beam rods
Stock crank, micro-polished and balanced
Oil squirters removed (more oil flow to the head, and forged pistons don't need the added cooling)
Cosworth 1.5mm HG
Ferrea +1mm Intake and Exhaust valves
BC dual wound valve springs
Garrett GT2871R .64 A/R Turbo
Tomei Expreme downpipe
Godspeed intercooler and piping
HKS SSQV2 BOV w/ option for recirculating
Nismo 740cc injectors
Plastic intake to head gasket/spacer (prevents heat soak into the intake manifold)
CXRacing aluminum radiator and dual 12" electric fans
Walbro 255 lph fuel pump
SARD adjustable FPR w/return line
Z32 MAF
Egay Catch can
Apexi N1 exhaust (no cat, no resonator, sounds super mean)
Fidanza 11 lb. flywheel (resurfaced when I did the rebuild)
Exedy Stage 4 clutch (replaced when I did the rebuild; less than 5k miles on it)
Aluminum 1 piece driveshaft
Complete R32 Skyline GTS-t rear end - 4.36:1 Final drive ratio, beefy 5 bolt axles
Touge Factory tuned ECU
Apexi SAFCII for running E85
Apexi AVCR Boost controller
AEM UEGO Wideband
Autometer Ultralite II Boost and Oil pressure gauges
Battery relocated to trunk
Turbo timer
FRESH OIL CHANGE ROYAL PURPLE
Suspension:
F: Tein Basic coilovers/R: GAB SS Shock and coil
Tein adjustable tie rods
Egay F and R strut tower bars
BRAIDED BRAKE LINES EBC PADS BREMO SLOTTED
Wheels and tires:
5zigen
Goodyear Eagle F1 F:225/35, R:245/35
Other:
Kenwood CD player w/ front auxiliary input (not sure of model, will double check)
Audiobahn 8" sub in a sealed box
Sony XPlod 250 Watt 2 channel amp for subwoofer
Full interior
Carbon fiber hood w/ hood pins
Sparco 4 point harness on driver's side
momo wood grain
+much more. ZERO RUST! NONE!!! just undercoated to preserve longer.
608-290-8514
alternator
starter
coils
full tune up
cracker moon roof
windshield
enthalpy ecu /chip
injectors
pump
fuel filter
rockerstoppers
or cash offer. 6k
Engine:
Eagle H-Beam rods
Cosworth 1.5mm HG
Z32 MAF
Egay Catch can
AEM UEGO Wideband
Turbo timer
Suspension:
Wheels and tires:
5zigen
Other:
Full interior
momo wood grain
krysted9354
May 11, 2011 01:17 PM
BALLIN H22 EK
Texas -OK -LA (Sales)
Jul 14, 2008 06:40 PM
