Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
continued noise front susp HFP
Old Aug 6, 2010 | 01:04 PM
kartman5's Avatar
Default continued noise front susp HFP
Thought I had the problem solved, but not quite. Replaced bump stops with new design'ed ones form Honda as well as front steering bearings. Was initially better, but the noise is back. Any thoughts? I'm just about ready tho throw out the HFP!
Old Aug 30, 2010 | 11:08 AM
LankorDie's Avatar
Loved
Community Favorite
Default Re: continued noise front susp HFP
Have you taken the Civic back to the dealership? Depending on the year this should be under warranty.
What type of noise is it? Can you decribe it in detail so I can help with a educated guess.
Old Aug 30, 2010 | 01:22 PM
testify's Avatar
On vacation
^^^ x2
Better desription of the noise would help with theories.
What is the car doing when it makes the noise? (going over bumps, turning, braking, etc...)
Is it on the right side, left side, both sides?
Clicking, creaking, banging?
Are there any other mods to the suspension like Swaybars, Endlinks, Control Arms, camber bolts?
Old Aug 30, 2010 | 03:00 PM
K5^'s Avatar
K5^
Brand New
Originally Posted by testify
^^^ x2
Note the title of this thread. This is an update regarding a noise described in a prior thread.
https://honda-tech.com/forums/honda-civic-2006-2015-79/fixed-noisy-hfp-front-suspension-2805240/
Old Aug 30, 2010 | 03:52 PM
testify's Avatar
On vacation
https://honda-tech.com/forums/showthread.php?t=2805240
Not tying to step on any toes around here K5^, but that thread doesn't say much. I'm new to these cars but I've been there and back with dozens of suspension setups on several different applications- and I've wracked my brain and done this multiple times with suspension woes. Just trying to help- its hard enough trying to diagnose a suspension problem when you are witness to it let alone when it is based on a good description on the internet.
Without a good description his only hope is that someone see's this thread that has had the same problem and "hole in one's it"...
*Ask me about Death Wobble*
Old Aug 30, 2010 | 04:17 PM
K5^'s Avatar
K5^
Brand New
Actually that was another update. The original thread was another that kartman created. From what I can surmise, the replaced bumpstops were a temporary fix.
Old Aug 30, 2010 | 05:11 PM
testify's Avatar
On vacation
Then based on his description in this thread
https://honda-tech.com/forums/honda-civic-2006-2015-79/noise-front-suspension-2780144/
And the fact that he has a FS thread for a subframe, etc...
I'd bet good money on a squeaky bushing somewhere.
Maybe swaybar endlinks, maybe CA bushings, etc...
My next question would be- does the noise go away in the warmer weather? Does the noise act up more when it rains.
Some bushing lube would be my first attempt at a fix.
Old Aug 30, 2010 | 05:28 PM
kartman5's Avatar
The noise was continual and bothersome. Worse at low speeds, but always present. No other suspension mods. After more investigation, the Honda dealership where I bought the set-up had so many problems with this set-up that they stopped carrying it.
I installed new bump stops and checked all other possibilities and eventually just put the stock suspension back on - problem solved. No noise at all with the stock set-up.
Very disappointed with Honda OEM quality. This along with all the misc. squeaks and rattles has pretty much soured me on ever buying another Honda. Good lucK!
Old Aug 30, 2010 | 07:25 PM
92civlude's Avatar
This may be far-fetched but its worth a shot. Ive seen more than a handful of these cars with loose dashboards. Yes... Loose Dashboards. Open the doors and at the the hinge area there are 3 round black buttons. These buttons are bolt covers. pop the covers off and see if the bolts are loose. Use a long 12mm wrench, snug em down.
Old Aug 30, 2010 | 09:05 PM
testify's Avatar
On vacation
WOW- what the heck am I getting into with my new investment!
Do you still have the HFP Springs/struts?
FS?
Old Aug 31, 2010 | 05:03 AM
kartman5's Avatar
Two of the loudest rattles I was able to fix:
-Pulled off the cover to upper portion of the drivers side door and put in extra padding.
80% of the rattle is gone. Will have to put in more.
-Pulled off the right rear part of the interior that covers the seat belt apparatus and padded various portions of it ( my mechanic). 100% of this rattle gone.
-New rattle developing in the same spot in the left rear door.
I'm hoping I may of gotten all of them. The drive train so far has been good, the rest of the
quality control - poor.
Old Aug 31, 2010 | 04:46 PM
kartman5's Avatar
Sorry, the HFP has been sold.
kenskii
Jul 8, 2014 08:33 PM
bignelson001
Mar 24, 2011 03:26 AM
kcari
Suspension & Brakes
Oct 28, 2009 12:30 PM
ibanezrgking
May 19, 2002 08:29 PM
