how do I remove the throttle body after taking out the 4 screws
Old Aug 6, 2010 | 12:08 PM
piggydog's Avatar
Default how do I remove the throttle body after taking out the 4 screws
The throttle body is still stuck after removing the 4 screws. I'm trying to get to the FITV (is there a way to remove/clean it without removing the throttle body? I'm tried hitting it with a mallet nothing seems to move it. Thanks
Old Aug 6, 2010 | 12:30 PM
minilogoguy18's Avatar
Default Re: how do I remove the throttle body after taking out the 4 screws
It's probably just stuck on, I'd bolt it back up though because the gasket can come apart when removing. You can remove the fast idle valve without taking out the throttle body, it's only 3 10mm bolts.
Old Aug 6, 2010 | 12:39 PM
piggydog's Avatar
how I can remove all the bolts, there are 3? 2 I see but it's upside down.
Old Aug 6, 2010 | 01:32 PM
Old Aug 6, 2010 | 02:17 PM
Kronn 98SH's Avatar
If people would just read the manual before posting, we'd have a lot less threads.
Old Aug 6, 2010 | 02:47 PM
Yeah especially when they can be downloaded from the spoon website...
One piece of advise that the manual doesn't talk about though, if you remove the back plate to tighten the plunger down, use red thread locker on the screws because mine fell out causing me to have to get the FITV from my H23a1 shipped to me from where I did the swap because you can't buy that plate.
Old Aug 6, 2010 | 04:16 PM
piggydog's Avatar
I have seen this before and I've done lots of searching. Looks like 3 bolts on the bottom of the throttle body. A very tough spot to get to for the standard tools I have.
Old Aug 7, 2010 | 02:41 AM
Tunerguy1989's Avatar
Well not to be mean but what kind of tools do you have? I took my throttlebody off with just a few simple wrenches and the FITV is even easier its less bolts(3), and taking out your intake piping would give you alot more room to work with. It really shouldn't be too tough unless your dealing with a car that hasn't been taking care of; or has been sittin around for 2 years plus.
Its simple I'm sure you'lll figure it out
Old Aug 8, 2010 | 01:37 PM
nus_dogg's Avatar
Yup, you can remove your FITV w/o removing the TB.
Old Aug 8, 2010 | 02:57 PM
Edul59's Avatar
but then this site will go to crap because there will be no action.
FTNW
Jan 10, 2012 04:39 PM
stackz
Oct 4, 2006 07:06 AM
Civic Hybrid
Jun 13, 2006 10:54 PM
onyx00
Mar 22, 2003 04:28 PM
