obd2a engine into 99 coupe
Old Aug 6, 2010 | 10:57 AM
60019184's Avatar
Default obd2a engine into 99 coupe
as title, im currently running a d16y7
in my 99 coupe which is obd2B.
How much wiring/modification
will be needed to make it run the
d16y8 which is obd2A?
Can i just change sensors from
my obd2b d16y7 and put them onto
the obd2a d16y8?
Old Aug 6, 2010 | 12:54 PM
jdmcivicracer89's Avatar
Default Re: obd2a engine into 99 coupe
usually u can just get away with doin a conversion harnass obd2a to obd2b to run ur stock ecu.
Old Aug 6, 2010 | 01:46 PM
60019184's Avatar
But will the obd2b loom plug onto the obd2a engine?
Old Aug 6, 2010 | 02:32 PM
94EG8's Avatar
Seagull Management
You'll need to use a '99 - '00 Y7/Y8 distributor (plug is different, Y5 wont work, they were OBD2A all the way through) Other than that simply use a conversion harness and the OBD2A ECU or get an OBD2B P2P ECU.
Old Aug 6, 2010 | 03:01 PM
60019184's Avatar
Never heard of a y5!
Oh so a obd2b loom will connect up to a obd2a engine? Didnt know that, learn something new everyday...
Old Aug 7, 2010 | 12:04 AM
60019184's Avatar
bump
mattvivsound
Feb 20, 2017 02:42 PM
Josh1999Civic
Jun 27, 2016 03:42 PM
Millenion LTD.
Jan 27, 2004 05:46 PM
