are these valve guides and piston rings compatible with my engine?
Old Aug 6, 2010 | 07:18 AM
gmbdelsol's Avatar
Default are these valve guides and piston rings compatible with my engine?
hi, i have a delsol jdm d15b 15vtec engine.
i want to buy a set of valve guides and a set of piston rings cause the ones i have needs to be replaced.
i have found a seller from the states that altogether including postage he told me are 305dollars the price is ok.
the problem is cause i dont know exxactly if they fit or not.
he told me this
From what I know the D15b cylinder head is the same as the D16z6 cylinder head that we have here in the states
So the valve guides for the d16z6 will fit the d15b
And the pistons the d15b pistons you have are a 75mm Bore ? if you can confirm that I can confirm the piston rings will work
thanks for your help/
4g4dcruisin
May 13, 2010 02:15 PM
qazaq
Jan 22, 2007 05:51 PM
crxhybrid1320
Jan 27, 2003 04:11 PM
