99 Accord V6 - Remote Key problems
Old Aug 6, 2010 | 06:52 AM
Danny.T's Avatar
Default 99 Accord V6 - Remote Key problems
Just got this car a few days, I knew the remote key not working. What I am trying:
1. Remote Key only working good on the trunk and panic buttons
2. Since the driver door unlocked, remote key only unlock one same door, the one behind the driver.
3. Lock/Unlock switch on the door panel acting same as the control key
Any help would be very grateful appreciate
Old Aug 20, 2010 | 09:25 AM
Danny.T's Avatar
Default Re: 99 Accord V6 - Remote Key problems
Up to date: I successfully replaced the door lock actuator on the dirver side. Now the front and rear locks on the driver side are working good on both remote key and door lock switch on the panel too. To make it easy for you to replace the actuator, you need to remove the bolt on the door frame to make the steel glass run inside the door get loose. Using small phillip screw driver for 1,2,3 screws, that's all.
I have no problem at all to replace the actuator. But I really gave up on PARTS GEEK, where I ordered 2 actuators, one left and one right (both front) but they sent me 2 Left. I call call and email email them for 2 days but cannot reach them.
I didn't open the right side door panel then I don't know if the atuators on L/R are the same? Anyone know? Please?
Thanks,
Old Aug 23, 2010 | 10:51 AM
gianinline's Avatar
Actuators will be different, basically everything is mirrored from one side to another.
Old Aug 24, 2010 | 03:05 AM
Danny.T's Avatar
I'm done, thank you all for your suggestions - Like I said, they sent me two identical left side actuators, I used one on the left door, the other I used only the motor for the right door. The deal: the motor alone costs me $25?
Now I will make a new post about security alarm....
Thanks
Danny
Old Jul 24, 2011 | 06:43 AM
welcher774's Avatar
I found OEM Genuine Honda parts at www.ushondaparts.com great prices
Amandaapples
Sep 11, 2024 01:51 PM
snapplez
Jul 27, 2013 04:23 PM
viper111
Jan 10, 2013 09:59 AM
pauwo
Feb 24, 2012 07:33 PM
Heat
Jul 4, 2003 07:26 AM
