do i need new spark plugs already??
Old Aug 5, 2010 | 08:35 PM
swizz977's Avatar
Default do i need new spark plugs already??
wen i first got my car it was boggin bad in the low rpms i guess missfireing or someshit and i changed the plugs and it ran great.. its starting to happen again tho and its only been like 2 months... is this normal for a old motor? 92 hatch stock 200xxx miles
Old Aug 5, 2010 | 09:32 PM
Former User's Avatar
Default Re: do i need new spark plugs already??
Have you checked the cap, rotor, and plug wires? Any CEL codes?
Old Aug 6, 2010 | 03:08 AM
semsem kane's Avatar
when you start engine in the morning does it talk more time to start ? if the answer is yes you must change it
and also clean idel , change fuel filter, clean air intake
Old Aug 6, 2010 | 04:37 AM
swizz977's Avatar
no i got a tune up.. new wires cap rotor new dizzy new fuel filter and intake
Old Aug 26, 2010 | 08:26 PM
swizz977's Avatar
bumpppppppppppp
Old Aug 26, 2010 | 08:37 PM
lunareg's Avatar
if they're copper plugs change every oil change they cost like 5 bucks?
Old Aug 26, 2010 | 08:40 PM
SeanK325's Avatar
that's overkill to the max. who changes their plugs every 3000 miles?
Old Aug 26, 2010 | 08:41 PM
lunareg's Avatar
i do lol.
but if your car is doing the same thing that changing plugs fixed than change em and see what happens.
Old Aug 26, 2010 | 08:44 PM
builthatch's Avatar
MiG-21 superfan
so when you changed the plugs last, was that done at the same time as your 'tune up' with the wires, cap, etc, etc?
Old Aug 26, 2010 | 09:47 PM
SeanK325's Avatar
i do lol.
well, at least you'll never worry about the plugs seizing lol
Old Aug 26, 2010 | 11:17 PM
chewyv's Avatar
pm4nudes
What brand and type/material of plugs did you put in? I know bosh plugs will crap on anything not german every now and again.
Old Aug 27, 2010 | 07:23 AM
swizz977's Avatar
yea ngks i gues il change them n see if it goes away but if it does what would be the cause of this
Old Aug 27, 2010 | 07:46 AM
builthatch's Avatar
MiG-21 superfan
if it does go away you are probably fouling the plugs somehow. fouling would be pretty evident on the plug at that point.
if it doesn't go away then you can be pretty confident that your issue is elsewhere.
Old Aug 27, 2010 | 08:23 AM
EJeff8's Avatar
I grabbed some bosch platinum on my last tune up like 2500 miles ago. Bad idea, they don't work as well as the old NGK's
Old Aug 27, 2010 | 08:33 AM
swizz977's Avatar
how do the plugs get fouled so fast?
Old Aug 27, 2010 | 09:19 AM
lunareg's Avatar
could be alot of things.. the plugs are to cold of a plug, could be running rich, it could even be the valve steam seals going bad.
Old Aug 27, 2010 | 09:47 AM
K20egcw's Avatar
What mods do you have done to your car? If your running to rich your plugs will foul, also if your running to cold of a plug they will also foul faster than normal.
Old Aug 29, 2010 | 07:36 AM
swizz977's Avatar
ok so it was the plugs i changed them last night car is running great not.. its only been a couple of months..
Old Aug 29, 2010 | 07:42 AM
vitamin_c95's Avatar
what do the old plugs look like? They can tell you a lot about how the engine is running.
Old Aug 29, 2010 | 08:16 AM
Zen Chameleon's Avatar
Chewyv, I have to praise you on your avitar Lmao! And I agree that Bosh plugs were a bad investment on my part
oh well
Old Aug 29, 2010 | 09:04 AM
swizz977's Avatar
the old spark plugs look fine
Old Aug 29, 2010 | 09:13 AM
michaelsej1's Avatar
bosch plugs dont do well in hondas at all!!!bosch spark plugs run hotter then ngk.and all though the last two hondas i had were over 230,000 miles and still kickin it,id forget spark plugs and swap that motor
Old Aug 29, 2010 | 09:26 AM
builthatch's Avatar
MiG-21 superfan
can you take macro shots of the business end or them? something that shows detail, like this?
Old Aug 29, 2010 | 02:16 PM
swizz977's Avatar
picssssssssssss
Old Aug 29, 2010 | 08:45 PM
swizz977's Avatar
