FS: OEM EG/D Series parts, head/intake/dizzy/energy suspension
All Items located in Attleboro MA, I go to school in Boston and work in Waltham, I am willing to drive reasonable distances to meet up.
All Prices are OBO, they fair in my opinion so don't waste both of our time by low balling me.
I am willing to ship the smaller stuff at the buyers expense.
I also have all of the components to chip P28 ecu's and burn chips, PM me for details.
On to the parts:
Brand New Energy Suspension Power steering bushing kit, fits ef/eg/da/dc and maybe more
$10
Brand New Energy Suspension rear lower control arm bushing kit for EF/EG does not fit integras.
$25
D16z6 Intake manifold and TB, came off of my car, upgraded to S2. TB has all sensors in working order, Intake needs IACV and air temp sensor
$60
D16z6 Head, came off my car, upgraded to a built head. Has approx 180K miles, used mobil 1 oil. needs a valve cover and vtec sol.
$100
EG Brake booster from my car, upgraded to integra booster
$20
7/8" EG brake master cyl, pulled from my car, upgraded to 1"
$20
EG Prop valve for rear drums
$10
EG Shifter, boot is a little bit ripped
5$
Stainless Steel T25 turbo gasket
$5
D series differential, 40mm bearings, with Speedo gear and EX final drive gear. Pulled from a working trans.
$25
Civic EX Transmission internals, full set of EX gears (bad countershaft bearing surface but rest are good.), shift change mechanisms, bolts, springs, second set of syncros, shims. Let me know what you need, probably have it, make offers.
EG Civic rear lower control arms, fresh bushings, approx 10K miles
$20
EG Civic Rear upper control arm, rear toe arm
$5
Unknown OBDII TB
$5
Brand new OEM Honda D16z6 Throttle body gasket, P/N:16176-p06-a01
$2
D Series clutch fork
$5
EG Civic Fuel pump and filter SOLD!
P28 Pistons and rods (d16z6)
$20
2 sets of D16z6 Injectors, both pulled from running engines, I hit one set with a wire brush
$20 each set
OBDII D16y8 Distributor repined for OBDI SOLD!
On to the parts:
$10
$25
$60
$100
$20
$20
$10
5$
$5
$25
$20
$5
Unknown OBDII TB
$5
$2
$5
$20
$20 each set
I don't have the master bushing set for sale, just the rear lower control arm bushings and the steering rack bushings.
The rear lower control arm bushing kit will fit your car, the power steering how ever will not.
cpl rampage
Aug 9, 2010 07:36 PM
