rim feels like its going to fall off
Old Aug 5, 2010 | 04:55 PM
09egkid's Avatar
Icon3 rim feels like its going to fall off
whats up HT im kind of a newb on here. i just wanted to get another opinion. when i take off my steering wheel shakes at low speeds and feels like my rim front driverside rim is gonna fall off checked lugs all tight. my second guess is tie rods. but my two outer tie rods are new...maybe inner?
Old Aug 5, 2010 | 07:02 PM
jdm27ef's Avatar
Default Re: rim feels like its going to fall off
its your wheel bearing..... i have the same problem unfortunately -_-
how long has this been happening to you? you might considering changing the inner tie rod too, and do the ball joint's since you are changing the wheel bearing. hope this help you man...
Old Aug 5, 2010 | 11:49 PM
dohc4life's Avatar
wheel bearing
Old Aug 6, 2010 | 02:10 PM
oh-yeahcrx's Avatar
So wheel bearing is more then likely the cause? Cause I have the samething. Like whenever the road gets rough that one wheel gets real loud like its about to fall off. Or doing a harder turn aswell.
Old Aug 6, 2010 | 02:18 PM
teamjdm239's Avatar
jack up your car, take your key out of the ignition, and make sure the steering wheel is locked. see how much play the wheel has by shaking it, and if there is alot of play, then it is in fact the wheel bearing. hope that helps.
Old Aug 6, 2010 | 02:35 PM
jdm27ef's Avatar
http://www.youtube.com/watch?v=cdRpn...eature=related
watch this and maybe this can help.
better fix it before this happen to you on the freeway.
http://www.youtube.com/watch?v=67RFy7z2pBU
Old Aug 6, 2010 | 02:54 PM
09egkid's Avatar
Thanks for all the tips....I'm a newb to the site not a honda lol.....but jacked it up popped the rim/tire off tire had a bubble on the tread. Problem solved
kelley_james
Jul 10, 2012 10:42 PM
jizno
Nov 23, 2005 01:57 PM
Takeoff
Feb 23, 2003 11:11 AM
nugget8000
Sep 24, 2001 02:08 PM
Rain_man
Jul 15, 2001 12:12 PM
