head question
Old Aug 5, 2010 | 04:00 PM
miguey310's Avatar
Default head question
if i change the head on my engine do i have to go get it cleaned or can i just bolt it right on ?
Old Aug 5, 2010 | 04:01 PM
ryanevansoh's Avatar
Default Re: head question
clean what? i would get the head gasket cleaned off and check the head for warpage if thats what you mean
Old Aug 5, 2010 | 04:04 PM
BiG ChOr!Zo's Avatar
take it to get resurfaced or if your baller status use a razor blade and scrape off the old headgasket if applicable...!!!
Old Aug 5, 2010 | 04:09 PM
miguey310's Avatar
what happens if i don't get it resurfaced ?
Old Aug 5, 2010 | 04:10 PM
miguey310's Avatar
btw can i use y8 not vtec head ?
Old Aug 5, 2010 | 04:13 PM
its only about $15-20 to get it resurfaced and checked from most little machine shops...!!!
Old Aug 5, 2010 | 04:14 PM
miguey310's Avatar
its only about $15-20 to get it resurfaced and checked from most little machine shops...also y8 is a vtec head...!!!
and what does resurfaced do ? i mean y7
Old Aug 5, 2010 | 04:21 PM
.Manny.'s Avatar
Touching My Member
Makes sure that the mating surface is nice and straight. Insures a nice seal.
Old Aug 5, 2010 | 06:03 PM
miguey310's Avatar
so can i use a y7 head ?
Old Aug 5, 2010 | 06:06 PM
miguey310's Avatar
does it matter if the heads are different ? like the y7 the spark plugs are low and the regular 88-91 sohc spark plugs are up
Old Aug 5, 2010 | 06:13 PM
sevwen7's Avatar
it doesnt matter cause your swapping the whole head. now if your just swapping the valve cover then youll have a problem
Old Aug 5, 2010 | 06:25 PM
Deetz's Avatar
Crazy Honda Guy
If you are putting a used and unfamiliar head on, having the head resurfaced means a clean swipe if the metal underside to it is both clean and straight...this ensures no head gasket sealing issues and makes for a proper installation
Old Aug 5, 2010 | 06:26 PM
miguey310's Avatar
will i get more power with a y7 head ?
Old Aug 5, 2010 | 06:29 PM
miguey310's Avatar
ah **** i'ma need a new dizzy with the y7 right ?
Old Aug 5, 2010 | 06:52 PM
D16SiHatch's Avatar
if you have an a6 now then the dizzy i believe should bolt up perfectly. i know it does on the y8 head anyway.
Old Aug 5, 2010 | 07:42 PM
miguey310's Avatar
no i was gonna get a a6 from some guy on H-t but i haven't gotten any word , i have a b1 at the moment , yes there a way that you can check if the head is in good condition ?
Old Aug 5, 2010 | 07:51 PM
http://www.instructables.com/id/Head...1-Honda-Civic/
Old Aug 5, 2010 | 07:53 PM
miguey310's Avatar
thanks
Flareside302
Jun 24, 2015 09:58 PM
hb_guy
Jan 16, 2006 07:31 AM
Hybrid
Feb 5, 2003 02:34 PM
