2001 Accord Lx *Low oil more frequent, MPG decrease, sticky throttle*
Old Aug 5, 2010 | 12:51 PM
yankie_1132's Avatar
Default 2001 Accord Lx *Low oil more frequent, MPG decrease, sticky throttle*
I have a 2001 Accord LX 2.3L. Milage is 175K. For the past 3 yrs or so, the throttle has been sticky. Found black gunk on the throttle body, after cleaning, it'll be good for awhile (10-20k miles), then comes back. Recently in Feb 2010, got a check engine with engine stall at RPM 4k. Code shows VTEC solenoid. After some research, it was due to low oil. Refilled oil, everything ok. Oil change in March. Issue came back again last month for CEL and low oil. I've noticed MPG hasn't been great anymore either.
-Am I burning oil? I don't see oil leaks in my drive way?
-Do I need a valve adjustment?
-Is something clogged?
Old Aug 5, 2010 | 03:12 PM
Accordin2me's Avatar
Default Re: 2001 Accord Lx *Low oil more frequent, MPG decrease, sticky throttle*
Replace the vtec solenoid and keep up on the oil changes, dirty oil will destroy the solenoid.
BTW: This will cure your mpg issue as well.
Old Aug 5, 2010 | 10:01 PM
i'm not sure the vtec solenoid is the problem though... it runs on oil pressure, and because pressure was low from low oil levels, it threw the CEL. i don't know what is consumming oil at this point.
Old Aug 6, 2010 | 02:46 AM
holmesnmanny's Avatar
How do you have vtec?
Old Aug 6, 2010 | 08:41 AM
comes with car.
Old Oct 7, 2010 | 08:15 AM
bump, no answers yet.
Old Oct 11, 2010 | 06:39 AM
94EG8's Avatar
Seagull Management
Have you taken a look at the PCV valve yet? If its plugged up it can cause oil consumption problems. Checked underneath for oil leaks yet? (note that sometimes the oil will leak over the exhaust and burn off so you wont see oil in the driveway)
Justin Domenic
Honda Accord (2013 - 2015)
Aug 2, 2018 10:07 AM
Metaccord
49
Apr 18, 2014 02:27 AM
theLemur
Nov 28, 2013 06:41 PM
roastbeefmike
19
Apr 17, 2012 12:05 PM
laloquera916
Feb 3, 2011 03:57 PM
